Plusnet routing issue?
- Plusnet routing issue?
15-12-2010 8:45 AM
anyone else on plusnet got the same issue?
by the way you can get to www.uservoice.com but this is a different site.
dick:green Link fixed.
Re: Plusnet routing issue?
15-12-2010 9:01 AM
I can get to both, although I couldn't by clicking on your link as I think you've not spelt it correctly. Anyone else having problems with it?
Jojo
15-12-2010 9:02 AM
15-12-2010 9:12 AM
tracert feedback.uservoice.com
Tracing route to uservoice.uservoice.com [75.126.16.218]
over a maximum of 30 hops:
1 1727 ms 99 ms 96 ms dsldevice.lan [192.168.1.254]
2 32 ms 33 ms 36 ms lo0-central2.pcl-ag04.plus.net [195.166.128.242]
3 27 ms 27 ms 26 ms gi1-12-421.pcl-gw01.plus.net [84.92.6.232]
4 * 27 ms * po4.pcl-gw02.plus.net [212.159.1.129]
5 * * * Request timed out.
6 * * po4.pcl-gw02.plus.net [212.159.1.129] reports: Destinati
on host unreachable.
thanks pierre_pierre for confirming this, an yes I mis-typed the www site!
15-12-2010 9:31 AM
I have spoken to Mark on the tech support line but he did not know how to escalate routing problems. He tried to blame it on the external site, but I repeated that your support staff both him and jojo can get to the site and so can my o2 mobile, so the problem lies with your router po4.pcl-gw02.plus.net [212.159.1.129] I repeated also that piere_piere has confirmed this too.
(P,S I know I mistyped the www site above)
I am not impressed 25 minutes on an expensive 0845 number to you and still did not get my problem looked in to.
I would like some of my service charge back to cover the cost of the call!
Also I hope my support question #37990657 does not take 15 hours to get looked in to as the estimate currently gives.
15-12-2010 9:45 AM
15-12-2010 9:50 AM
Perhaps at the end of this you could add to the support system a pre-written question for these types of issues so they go straight to the routing infrastructure team and also let Mark know how to escalate them in the future.
Again I thank you for your time.
dick:quote
15-12-2010 9:51 AM
Could you redo your tracert as it appears you are trying to trace to uservoice.uservoice.com and not feedback.uservoice.com?
15-12-2010 9:56 AM
first in case I had a stale lookup
but it does return uservoice.uservoice.com as the answer again in the traceroute, do you get a different answer then?
C:\Users\ndl>ipconfig /flushdns
Windows IP Configuration
Successfully flushed the DNS Resolver Cache.
C:\Users\ndl>tracert feedback.uservoice.com
1 149 ms 99 ms 99 ms dsldevice.lan [192.168.1.254]
2 44 ms 33 ms 34 ms lo0-central2.pcl-ag04.plus.net [195.166.128.242]
3 28 ms 27 ms 27 ms gi1-12-421.pcl-gw01.plus.net [84.92.6.232]
4 * 27 ms 27 ms po4.pcl-gw02.plus.net [212.159.1.129]
Trace complete.
dick:quote
15-12-2010 9:58 AM
15-12-2010 10:00 AM
15-12-2010 10:07 AM
Yes that fixed it and (http://feature.astaro.com which is the same site)
what was the prob then dns issue or dodgy router route?
Any chance of getting some of that wasted phone call money credited against my next months sub please?
[Moderator's note by Adie (Adiewoo): Full quote of preceding post removed, as per Forum Rules ]
Please use the 'Reply' button rather than the 'Quote' button.
15-12-2010 10:12 AM
Quote what was the prob then dns issue or dodgy router route?
The advertised route on the piece of hardware was incorrect.
Quote Any chance of getting some of that wasted phone call money credited against my next months sub please?
We don't generally reimburse calls to our support line if I'm being honest, however if you're with Plusnet homephone then calls to our support line are free, BT I believe give free calls to 0845 numbers on most tariffs as do some other providers.
15-12-2010 10:23 AM
I am not a plusnet home phone customer, nor a BT customer so my calls to that line are at the most expensive rate going.
I feel you should make an exception in this particular case as the issue was a problem with your network, which it has taken an hour and a quarter of my time to help you resolve
and the customer service agent was not trained sufficiently in knowing where to escalate this problem to and not resolving the issue after leaving me on hold for 15 mins ( that does not include the 10 min wait to get through).
All I am asking is for one months service charge credit to cover these costs, i should not have to pay to report problems with your network.
But again I thank you for your effort - you have been brilliant.
I hope you will now go back and help Mark to know how to escalate this properly in the future and may be improve the support wizard to have a category for suspected routing issues.
15-12-2010 11:22 AM
