FTTC Modem sync speed/stats etc.
- Full Fibre
- FTTC Modem sync speed/stats etc.
24-11-2010 9:28 AM
Does the BT FTTC modem have a web interface (or similar) where one can see the line's sync speeds, noise levels etc. like most ADSL routers support? I've generally been keeping records of my ADSL sync speeds and reconnections and would like to do the same after my FTTC install on Friday.
Message 1 of 5
(2,244 Views)
4 REPLIES 4
Re: FTTC Modem sync speed/stats etc.
24-11-2010 11:11 AM
No.
Message 2 of 5
(718 Views)
24-11-2010 12:17 PM
Had a feeling someone might say that
Message 3 of 5
(718 Views)
24-11-2010 3:40 PM
Have a look at SIN 498 here - http://www.sinet.bt.com/ gives a lot of background technical information...
Message 4 of 5
(718 Views)
24-11-2010 5:05 PM
You can run the BT Speedtest as this will give you the IP profile, can't remember whether it shows the sync speed as well but it's about the best you have. On our side I can run a test which shows the sync speed but no other line stats.
Dave Tomlinson
Plusnet Technology
Plusnet Technology
Message 5 of 5
(718 Views)
- Full Fibre
