Understanding the speed of BB Your Way vs the new packages
- Understanding the speed of BB Your Way vs the new ...
15-11-2010 2:18 PM
For this billing period I requested the 60Gig dowload cap for an up to 20Mbit connection, on a replacement TG585 v8 router - and it's slower so far. Once my current ticket is closed and the line gets back to the optimal speed, if it doesn't improve, any issues with requesting a move back to an equivalent option 2 for my next bill date next month? Faster downloads on a smaller cap are what I've been used to.
Re: Understanding the speed of Value 2 vs the new packages
15-11-2010 2:21 PM
Are you referring to sync speeds or download/speedtest speeds
15-11-2010 2:33 PM
Found the original Email it was "Broadband Your Way" back in 2008 and have edited the thread title for any confusion.
15-11-2010 2:37 PM
15-11-2010 2:41 PM
Link Information
Uptime: 0 days, 2:53:02
DSL Type: G.992.1 annex A
Channel mode: Interleave
Maximum Bandwidth (Up/Down) [kbps/kbps]: 1,148 / 6,048
Bandwidth (Up/Down) [kbps/kbps]: 448 / 6,016
Data Transferred (Sent/Received) [kB/MB]: 0.00 / 32.14
Output Power (Up/Down) [dBm]: 11.5 / 19.5
Line Attenuation (Up/Down) [dB]: 17.5 / 32.5
SN Margin (Up/Down) [dB]: 27.0 / 16.0
Loss of Link (Remote): 0
FEC Errors (Up/Down): 0 / 392
CRC Errors (Up/Down): 0 / 0
HEC Errors (Up/Down): 0 / 0
15-11-2010 2:45 PM
your default noise margin has bounced up to 15dB which has restricted your speed.
this was probably a side effect of going to ADSL2+
This will need a staff member to jump in to see if there is an obvious reason for it - perhaps a lot of disconnections during the training period
15-11-2010 3:06 PM
I've just matched your PN & BT profiles to 5000k so if you disconnect and reconnect via your router homepage you should see this difference.
@Jim, he's on ADSL1 on 21CN btw.
Jojo
15-11-2010 3:10 PM
How about moving him to ADSL2+ which will start a full retrain and perhaps fix the problem and give better speeds into the bargain
15-11-2010 3:13 PM
I think the main thing is that the PN profile was 2000 before I changed it.
Jojo
15-11-2010 3:15 PM
15-11-2010 3:17 PM
Of course, it's possible to move him to ADSL2+
If you want to do that, nethlyn, just let me know and I can get it ordered. Normally takes about a week.
Jojo
15-11-2010 3:26 PM
Any price difference on ADSL2+ compared to the Extra I took up 6 days ago? Or am I mixing up a package with the connection type?
I think what I'll do is close my ticket from overnight, see where my connection gets back to after the 3-4 days of the router being on as I was in the habit of turning everything off overnight. Since it takes a week anyway to go to ADSL2+ then it won't matter, as posted below, please go ahead with the order
15-11-2010 3:31 PM
Looking at you stats you should see a nice speed increase.
15-11-2010 3:40 PM
Quote from: Joanne Hi Jim,
Jojo
Given the info from Jelv, if you can make this order within this billing period straight after a tariff change then please do so Jojo, If my exchange and router can hack it then might as well get the best possible speed.
Re: Understanding the speed of BB Your Way vs the new packages
15-11-2010 3:56 PM
Yeah, sure thing, I'll order that for you now and it should be working after 7 days.
Jojo
