Webmail
- Webmail
Webmail
17-09-2010 12:13 PM
Hi All
I am geting kicked out of webmail with in less van 1 minute I am geting the Error Message:
Quote ERROR
You must be logged in to access this page.
Go to the login page
Quote ERROR:
ERROR: Connection dropped by IMAP server.
Message 1 of 9
(3,922 Views)
8 REPLIES 8
Re: Webmail
17-09-2010 12:31 PM
This service status probably explains it, have you retested since?
Message 2 of 9
(956 Views)
Re: Webmail
17-09-2010 2:33 PM
Everything seams to be back to normal now!
Message 3 of 9
(956 Views)
Re: Webmail
22-09-2010 12:07 PM
Hi All
Again
Quote ERROR:
Again
Message 4 of 9
(956 Views)
Re: Webmail
22-09-2010 12:52 PM
Thanks for flagging this, I've replicated the error from our side so I've sent a ticket through to the Networks Team on your account to look into and resolve the problem.
Update: Networks have replicated the problem too but have been unable to pin down the underlying cause. They've raised a problem to investigate further but as this issue appears to only be affecting your account, other problems will have higher priority. In the meantime I'd recommend that you use mail2web or a standalone client set up to collect your email over IMAP
Message 5 of 9
(956 Views)
Re: Webmail
22-09-2010 7:16 PM
Thanks Ben.
Message 6 of 9
(956 Views)
Re: Webmail
27-10-2010 9:33 PM
This is getting annoying.
Quote ERROR
This page request could not be verified and appears to have expired.
Message 7 of 9
(956 Views)
Re: Webmail
28-10-2010 1:01 PM
Update this is what is going on to day:
Then with in 30 seconds I get this:
Logout then back in and with in 40 seconds I get this:
Logout then back in and get this:
Quote ERROR:
ERROR:
Query: EXPUNGE
ERROR:
Quote ERROR
Quote ERROR:
Message 8 of 9
(956 Views)
Re: Webmail
04-11-2010 11:55 AM
Had a bit of this here as well recently. All working fine now so I will wait and see. I am also a bit suspicious of my router (Plus.net Voyager 210) which seems to be more unstable as well. Last night sometime the DSL and Internet lights went out (should be on 24/7, but computer not left on), I rebooted this morning and all OK now. Download speed much as normal, in the 1.5 to 3.0 Megs range over most of this year.
Any advice?
Any advice?
Message 9 of 9
(956 Views)
