21CN SNR resets
- 21CN SNR resets
21CN SNR resets
13-09-2010 10:20 AM
Detail here.
Re: 21CN SNR resets
13-09-2010 10:40 AM
Does this part apply when a reset was done as part of the "no DLM" trial
Quote CCSNR works by triggering a signal to noise ratio reset and subsequently a maximum stable rate (MSR) and fault threshold rate (FTR) re-calculation. A BRAS profile change will also be performed (if applicable) when the circuit synchronises next time. The MSR will either rise or remain unchanged - it can never go lower.
Re: 21CN SNR resets
13-09-2010 11:10 AM
Re: 21CN SNR resets
13-09-2010 12:39 PM
Graham
Re: 21CN SNR resets
13-09-2010 1:02 PM
Re: 21CN SNR resets
13-09-2010 3:46 PM
Graham
Re: 21CN SNR resets
13-09-2010 3:53 PM
My external ip address has been reset a few times overnight...
Quote 11/09/2010@17:00:01 87.xxx.77.aaa
11/09/2010@17:15:01 87.xxx.77.aaa
11/09/2010@17:30:01 87.xxx.77.aaa
11/09/2010@17:45:01 87.xxx.77.aaa
11/09/2010@18:00:01 87.xxx.77.aaa
11/09/2010@18:15:02 87.xxx.77.aaa
11/09/2010@18:30:01 87.xxx.77.aaa
11/09/2010@18:45:01 87.xxx.77.aaa
12/09/2010@01:45:01 87.xxx.77.aaa
12/09/2010@02:00:01 87.xxx.77.aaa
12/09/2010@02:15:01 87.xxx.77.aaa
12/09/2010@07:15:01 87.xxx.77.aaa
12/09/2010@07:30:01 87.xxx.77.aaa
12/09/2010@21:45:01 87.yyy.162.bbb
12/09/2010@22:00:01 84.zzz.175.ccc
12/09/2010@22:15:01 84.zzz.175.ccc
12/09/2010@22:30:01 84.zzz.175.ccc
12/09/2010@22:45:02 84.zzz.175.ccc
12/09/2010@23:00:01 84.zzz.175.ccc
12/09/2010@23:15:01 84.zzz.175.ccc
12/09/2010@23:30:01 84.zzz.175.ccc
12/09/2010@23:45:01 84.zzz.175.ccc
13/09/2010@00:00:01 84.zzz.175.ccc
13/09/2010@00:15:01 84.zzz.175.ccc
13/09/2010@07:15:04 84.zzz.175.ccc
13/09/2010@07:30:02 84.zzz.175.ccc
13/09/2010@07:45:01 84.zzz.175.ccc
13/09/2010@08:00:02 84.zzz.175.ccc
13/09/2010@08:15:01 84.zzz.175.ccc
13/09/2010@08:30:01 84.zzz.175.ccc
13/09/2010@08:45:01 84.zzz.175.ccc
13/09/2010@09:00:01 84.zzz.175.ccc
13/09/2010@11:45:01 84.zzz.175.ccc
13/09/2010@12:00:02 84.zzz.175.ccc
13/09/2010@12:15:02 84.zzz.175.ccc
13/09/2010@12:30:02 84.zzz.175.ccc
13/09/2010@12:45:01 84.zzz.175.ccc
13/09/2010@13:00:01 84.zzz.175.ccc
13/09/2010@13:15:01 84.zzz.175.ccc
13/09/2010@13:30:01 84.zzz.175.ccc
13/09/2010@13:45:01 84.zzz.175.ccc
13/09/2010@14:00:01 84.zzz.175.ccc
13/09/2010@14:15:01 87.yyy.mmm.nnn
The blue addresses seem to be pretty stable.
