LLU Query
- LLU Query
LLU Query
06-08-2010 4:08 PM
Re: LLU Query
06-08-2010 4:37 PM
Re: LLU Query
06-08-2010 6:42 PM
Quote from: julesandsand what, if any, are the (potential) benefits?
Depending on your exchange and suppliers active there you may get ADSL2+ if BT aren't doing it yet ("up to" 24mbps).
Whether this is of any use will depend on how far you are from the exchange (attenuation) and whether higher speeds are actually any use to you.
You will escape BT's DLM, if this has been a problem for you. Different LLU suppliers have their own different systems so whether this is an advantage will depend on what problems you've had.
There are other differences, but those are the main ones I encounter regularly.
Re: LLU Query
06-08-2010 8:23 PM
Re: LLU Query
06-08-2010 8:55 PM
Re: LLU Query
06-08-2010 9:18 PM
Re: LLU Query
07-08-2010 10:13 AM
Re: LLU Query
07-08-2010 11:50 AM
Re: LLU Query
10-08-2010 2:05 PM
If another provider has promised anything more for you then we can always re-visit this and see if there's anything that we can do, who's tempting you at the moment?
Re: LLU Query
11-08-2010 3:49 PM
Click this link and view the additional log that appears.
Quote from: pierre_pierre , not sure about Orange or Bulldog
http://www.bulldogbroadband.com/
Re: LLU Query
11-08-2010 3:54 PM
Re: LLU Query
11-08-2010 5:26 PM
Re: LLU Query
11-08-2010 7:35 PM
Re: LLU Query
25-08-2010 8:17 PM
Re: LLU Query
25-08-2010 9:32 PM
