new phone and broadband customer
- Feedback
- Plusnet Feedback
- new phone and broadband customer
12-07-2010 12:50 PM
using the Internet from my local library today
I'm a new phone and broadband customer
phone went live today 12th july and that works fine
I'm waiting for my cable router and hopefully I can physically install it and
run an ethernet cable up to my desktop without any problems
I need a plusnet email address as I didnt create one during signup
Could do with some one who knows how to do this to make a post , thanks
as I've probably lost my previous tiscali/toucan email address.
need to check that ,
Re: new phone and broadband customer
12-07-2010 1:24 PM
Don't worry if you didn't create an address using sign up, just follow this link: https://portal.plus.net/my.html?P%2BVHYN6YBvn5XnJBpBx5LxGvNgoXUgKqC3f0fFmIgOsmrrsujjYNOoAbUr2%2FgAxC... login and click 'create new mailbox'
If you need any help setting up an e-mail client like Outlook or Outlook express after that this should also help: http://www.plus.net/support/email/setup/settings.shtml
Just give us a shout back on here if you have any problems.
12-07-2010 3:32 PM
12-07-2010 4:16 PM
12-07-2010 8:26 PM
I've managed to connect to here using my usb thompson speedtouch ASDL modem that i got when i joined toucan internet 5 years ago
It works okay
hmmm
12-07-2010 8:31 PM
I may need advice , all though I'm an engineer hmm
About the plusnet router
I ddnt want wireless, as i like wires , i accepted what was offered when i signed up with plusnet
strange my earlier modem works
any ideas why i cant use it permenantly
12-07-2010 9:23 PM
12-07-2010 9:36 PM
it is working hence i'm able to use the internet, and this forum
I shall use it untill i go onto the plusnet extra package
tc Oldjim
12-07-2010 10:51 PM
Quote from: magnetism2772 About the plusnet router
The PN router will be fine with ethernet - just disable the wireless facility.
Quote from: magnetism2772 strange my earlier modem works
You can use it, but I wouldn't advise it once you've got the router.
A router separates the WAN (Internet) from your LAN (one or more PCs) and is so called because it routes (requested) packets between your public IP address and the IP address(es) of your computer(s), and thus inherently provides a hardware firewall. A USB modem is 'wide open'.
Routers tend to more reliable, too, and are not reliant on drivers within the PC.
Plus, of course, the general consensus is that to avoid DSLAM problems, eg Target Margin rising, routers are best left on 24/7, which with a USB modem would entail having the PC on 24/7.
Zen FTTC 40/10 + Digital Voice FRITZ!Box 7530
BT technician (Retired)
13-07-2010 1:56 PM
I also know I now have plusnet broadband on the ends of my phone line
just informing the plusnet team
that a plusnet parcel turned up today, 13th July - opening the box - title of my youtube video - imao
inside was a jazzy router , complete with installation instructions and a micro filter , a small length of broadband cable (looks like telephone cable )that fits in between the broadband cable and the POTS (plain old telephone system)telephone socket
telephone socket is downstairs , my desktop upstairs , so i'm running a longer piece of ethernet (patch)cable up the stairs and into a bedroom
thats the only hard bit , as i will need to clip the cable as i go
I shall do that part a little later
I'm impressed , but its now lunch hour - so tools have been put back into my toolbox
13-07-2010 3:02 PM
13-07-2010 4:30 PM
I'm now using plusnets router it was really easy to connect up
just need to purchase some clips to clip in my ethernet run up to the bedroom
tomorrow,
I'm fully plusnet now , all the old equipment from toucan has been removed
the only tools I needed to do the job was a cloth
thanks all
its all systems go
cant create an email address yet it tells me to wait 30 minutes
even wiped my phone a little bit
13-07-2010 4:35 PM
plusnets web page displays
If you are an existing customer
Unfortunately, this feature is not available with your current account. To raise any queries and to upgrade your account, please use the Contact Us tool here at the Portal
If you have recently joined PlusNet
It may take up to 30 minutes until you can access this feature of your account. Please try again later. Go back
13-07-2010 9:33 PM
well done plusnet
i'm not being allowed to create email
ie my first e-mail address
leaving that for another day
13-07-2010 9:34 PM
