SPF record
- SPF record
SPF record
21-06-2010 11:11 AM
We send our email out via relay.plus.net and are having problems with emails being rejected due to an incorrect SPF record.
Can anyone tell me the correct SPF entry required to pick up all the plus.net outgoing email servers.
Message 1 of 7
(3,637 Views)
6 REPLIES 6
Re: SPF record
21-06-2010 1:21 PM
SPF records help identify its only you sending the mail...
check SPF
Why do you relay your mail through relay.plus.net? from the sounds of it you have your own mail platform? (if yes, why dont you just send the mail out yourselves - you will still need an SPF record though - as other people may drop your emails)
check SPF
Message 2 of 7
(1,712 Views)
Re: SPF record
21-06-2010 2:02 PM
Because the likes of hotmail and AOL will not except mail from a server with a dynamic IP and all IP's issued by PN are classed as dynamic even the static ones. Also you don't get indication from them that they have refused delivery of the emails.
This is my spf entry which work but I believe can be improved. Believe the mx and 212.159.xx.xxx declarations are the same. The ip4:212.159.7.0/24 cover the subnet which PN server are on. Use to specify the actual IP's for each server but PN have/do more them so went for the subnet to cover this.
"v=spf1 mx ip4:212.159.xx.xxx ip4:212.159.7.0/24 -all"
Message 3 of 7
(1,712 Views)
Re: SPF record
21-06-2010 2:10 PM
Quote from: itsme Because the likes of hotmail and AOL will not except mail from a server with a dynamic IP and all IP's issued by PN are classed as dynamic even the static ones. Also you don't get indication from them that they have refused delivery of the emails.
Thanks,
I've just put the ip4:212.159.7.0/24 in our spf record. I wasn't sure if there were anymore needed, or if there was something I could put in that would automatically take care of any changes in PlusNet's outgoing email server ip changes.
Message 4 of 7
(1,712 Views)
Re: SPF record
21-06-2010 2:55 PM
Hello chap
Sorry didnt think of this before, but it helped me when i was trying to get a grip of SPF
Microsoft's SPF Wizard
(i had issues with hotmail just randomly dropping my email - redid it using their wizard and ive had no issues from anyone (except anyone i block outgoing too )
Hope all is well, worth remembering that SPF doesnt update instantly - so you have to tweak then hope its right
Message 5 of 7
(1,713 Views)
Re: SPF record
21-06-2010 3:55 PM
Quote from: vceuser I've just put the ip4:212.159.7.0/24 in our spf record. I wasn't sure if there were anymore needed, or if there was something I could put in that would automatically take care of any changes in PlusNet's outgoing email server ip changes.
Try this:
v=spf1 mx include:madasafish.com
Message 6 of 7
(1,713 Views)
Re: SPF record
22-06-2010 8:39 AM
Quote from: Bob
Try this:v=spf1 mx include:madasafish.com
Excellent - Just the thing I was after.
Message 7 of 7
(1,713 Views)
