Domain registered, now how to point at CCGI?
- Everything else
- Domain registered, now how to point at CCGI?
01-06-2010 12:03 PM
Just got my domain registered with PlusNet for my blog and would now like it to point to my CCGI instead of asking people to type in the huge CCGI address. Is there an easy way to achieve this?
Tom
Re: Domain registered, now how to point at CCGI?
01-06-2010 11:51 PM
Left Field Type Pri Right Field
yourdomain.com. A 84.92.1.4
www CNAME yourdomain.com.
Make sure you add the trailing dot to the domain names
Then call tech support and ask them to enable the domain for ccgi access
That's it - you're done
02-06-2010 11:21 AM
02-06-2010 11:24 AM
The MX record is for mail deliery only.
You can leave that as it is unless you intend to change the method of collecting your mail - Eg: using your own MS Exchange mail server.
02-06-2010 1:51 PM
"If you wanted to keep your whole website on the CGI server (not recommended) create the record as follows..."
Can anyone tell me why it is "not recommended"
03-06-2010 4:49 PM
The post from editpoint helped me out, got the domain looking in the right place but its still not right.
The domain is www.prongle.co.uk
I need to to point at http://ccgi.tompringle.plus.com/~tompringle/wordpress/ - However its just not doing it. If I type www.prongle.co.uk/wordpress it instantly defaults to http://www.prongle.co.uk/~tompringle/wordpress/ ; But I have to manually type 'wordpress'
Without reinstalling the whole wordpress package again can I get the domain to point directly at http://www.prongle.co.uk/~tompringle/wordpress/ ?
03-06-2010 6:19 PM
RewriteEngine on
RewriteBase /
RewriteCond %{REQUEST_FILENAME} -d
RewriteRule ^(.+[^/])$ $1/ [R,L]
RewriteCond %{HTTP_HOST} ^(www\.)?mydomain\.co\.uk$ [NC]
RewriteCond %{REQUEST_URI} !^/~username/folder/
RewriteRule (.*) /folder/$1
changing mydomain, username and folder (twice) appropriately, then your domain will point straight at your blog. The explanation for this can be found in the post linked from section 8 of the faq.
Gabe
Edit: typo
03-06-2010 7:07 PM
No setting changed since I last logged into the CCGI and now when I try to connect I get this;
Status: Resolving address of ccgi.plus.net
Status: Connecting to 84.92.1.4:21...
Status: Connection attempt failed with "ECONNREFUSED - Connection refused by server".
Error: Could not connect to server
Status: Waiting to retry...
Status: Delaying connection for 1 second due to previously failed connection attempt...
Any ideas?
04-06-2010 8:45 AM
Gabe
13-06-2010 8:24 AM
Trying to connect to the CCGI via a telnet request gives me this error
[tt]Trying 84.92.1.4...
telnet: connect to address 84.92.1.4: Connection refused
telnet: Unable to connect to remote host
[/tt]
So according to this I can't even connect to the server? I'm guessing this means it isn't an FTP client problem as the test was taken place in a terminal window.
13-06-2010 8:26 AM
Me = Clown
Started happening when I returned to the Midlands and used our Virgin internet connection. Problem solved. Will have to wait till I return down south to try and fix the redirecting issues.
13-06-2010 2:24 PM
10) I can't connect to the FTP server
Please be mindful that you will need to be connected to the Plusnet network before you'll be able to FTP to the CGI servers. You will not be able to do this from another ISP's network. If you can connect to the FTP servers but they are not accepting your username or password then please raise a support ticket on your account so that we can reset your password.
23-06-2010 10:21 AM
25-06-2010 9:02 AM
Quote from: TomP I'm guessing this is permissions playing up and I will have to wait until I'm back on a PN connection to sort it out?
Unless you happen to have left a script such as this in your root.
Gabe
- Everything else
