I referred a neighbour and he's 2mbps faster than me!
- I referred a neighbour and he's 2mbps faster than ...
17-05-2010 3:34 PM
Re: I referred a neighbour and he's 2mbps faster than me!
17-05-2010 3:46 PM
Also post your full router stats - noise margin, attenuation and speeds
17-05-2010 4:06 PM
17-05-2010 10:23 PM
Quote from: Oldjim First thing is to connect to the test socket and see what the results are.
Congratulations...
You've lost me already
17-05-2010 10:31 PM
to get your router stats see here http://kitz.co.uk/adsl/frogstats.php
18-05-2010 9:18 AM
input your attention here and it will give a best effort result (6db noise margin) for your line
http://www.kitz.co.uk/adsl/max_speed_calc.php
if your router reports 63db attention, then its likely your atten could be higher as most routers do not report an attention value higher than 63db.
18-05-2010 9:42 AM
Quote from: pierre_pierre look at the picture, that is the test socket
Merci Pierre....
My router reports as follows....
Download Conn. Speed. 5056 kbps Attenuation 36db Noise 15 db
Upload 448 kbps 11.5db 21 db
Speed this morning on Speedtest.net is 3.6 Mbps
Would it be OK if I connected our laptop to the test socket, it would be a major pain in the *** to connect my main PC.
18-05-2010 10:00 AM
18-05-2010 10:22 AM
I plugged the filter into the test socket and then repeated the procedure that gave the earlier results.
The new results were identical except for a higher download speed of 5216,
adie:quote
18-05-2010 10:30 AM
18-05-2010 10:33 AM
Quote from: jelv How often do you turn your router on and off?
I never turn it off.
Might it be relevant that I run three Internet radios on my network?
19-05-2010 8:06 AM
19-05-2010 8:18 AM
They will have a better idea of any line instability you may have which can cause an increase in the noise figure. and a subsequent decrease in your profile.
19-05-2010 11:27 AM
I can't see any drops in your connection logs that may be causing this, but there's definitely some interference somewhere that's causing the sync rates to fluctuate (though not by much - since Feb it's moved from ~4.5mb through to 6.5 and now back to 4mb).
I'd recommend double checking your filters and also testing the connection with the router in the master socket with all other items removed from the line in order to confirm that these aren't causing the changes, if the sync rate is improved when the line is in this state then plug things back in one by one and see which makes the difference.
Hope that helps,
19-05-2010 1:34 PM
