Settings for ADSL2+
- Settings for ADSL2+
Settings for ADSL2+
05-05-2010 7:47 AM
However do I need to alter any settings in my router (Netgear DG834) to make ADSL2+ fully functional? My search attempt in the FAQs have found nothing so far.
Re: Settings for ADSL2+
05-05-2010 8:54 AM
05-05-2010 9:25 AM
BTW router is v3 with latest firmware with no wireless network. OS is Win7
05-05-2010 10:10 AM
05-05-2010 10:19 AM
As for the image stallan has posted, I think this is using the DGTeam firmware not the standard Netgear, so you won't see that option on yours.
05-05-2010 10:20 AM
05-05-2010 11:42 AM
05-05-2010 11:53 AM
Just in case
Quote from: adiewoo ... it should be set up to switch automatically between modes...
I need to do a manual config. Where can I find the appropriate settings?
05-05-2010 12:05 PM
Web interface upgrades have been known to brick the router which isn't an issue as you can upgrade using one of the above utilities afterwards but might as well save yourself the trouble to begin with
05-05-2010 12:30 PM
http://en.wikipedia.org/wiki/ITU_G.992.5
My Linksys router has a dropdown menu with different options, but is actually set to multimode
05-05-2010 1:05 PM
From qyestions
Quote from: Vip3r lucerne, in the tickets you have about your upgrade, do they explicitly say that you have been upgraded to 21CN or ADSL2+?...
and the date should be 11-12/5. from another ticket.
Quote Provisioning of your ADSL Account Information
Pending Provisioned Service \'WBC MAX24 mb/s (ADSL2+ Annex A)\' added as a part of Account Change process
05-05-2010 8:32 PM
05-05-2010 8:37 PM
No amount of router reconfigs or reboots is going to get you an ADSL2+ connection as it is locked at the exchange.
05-05-2010 10:05 PM
06-05-2010 8:08 AM
