Recent calls not updated
- Home Phone
- Recent calls not updated
19-01-2010 10:40 AM
I can't see call updates since 12th Jan. I know I have made calls, and I must be close to if not over my monthly included allowance.
Any idea when this will be updated? If not before my billing date, will any calls above my allowance be rolled over into the next month, or will I be billed retrospectively once the records are updated?
Re: Recent calls not updated
19-01-2010 11:20 AM
19-01-2010 12:48 PM
19-01-2010 1:28 PM
Thanks Pierre. I hadn't thought to look there
19-01-2010 1:51 PM
@robr I can see calls showing up to the 17th for your line in both 'recent calls' and 'itemised bill'
@maranello I can't see why the calls you've made aren't showing up, are they to UK landlines/mobile or international numbers?
19-01-2010 2:09 PM
Hi Chris. Calls were made to UK landlines. No mobile or international calls.
19-01-2010 2:12 PM
19-01-2010 2:17 PM
Thanks Chris, but please don't try too hard to find the problem, I won't be overly disappointed if the call records have been lost
20-01-2010 8:06 AM
A call made to New Zealand weeks ago has still not been recorded. Mand said sometime ago that "we've found a problem with NZ calls, basically some of the destinations have been renamed by BT Wholesale, so we need to update our systems to match. This is why your call is not appearing (because it doesn't match any destination in our system).". Obviously the update hasn't been done, can't really understand why BT has to rename mainland NZ!!!!
20-01-2010 8:51 AM
20-01-2010 9:17 AM
20-01-2010 9:27 AM
Strangely though, another account I look after is up to date to the 18th!
20-01-2010 9:43 AM
Quote from: Chris @robr I can see calls showing up to the 17th for your line in both 'recent calls' and 'itemised bill'
You're right, 4 days worth of data all appeared together not long after I posted. Still seems to be running a couple of days behind though.
20-01-2010 9:47 AM
20-01-2010 12:53 PM
