Sunday 21st March 2010Login | Register | Help
Pages: [1]
Google Picasa has taken over "Windows Print Wizard"...
« on 19/11/2009, 15:24 »
Hi all,
Myself and the in-laws are both running Google Picasa (3.5.x), but we've noticed something different on the two machines (both Windows XP_SP3).
If I "right-mouse-click" (e.g. bring up the "context menu") on a ".jpg" file when using Windows Explorer, the Windows "Print Wizard" kicks in, and I can print o.k. However, when the in-laws do the same action, the print function from Picasa kicks in.....
I've tried looking at Windows Explorer "Tools"->"Folder Options", "File Types" tab, as I seemed to recall that you could edit which application performed certain actions  (e.g. open, edit, print, etc.) in the context menu on a per file type (extension) basis. But when I look at "jpg" extension, where the "Advanced" button normally is, there is now a "Restore" button. And that's on the system that's working "natively" - e.g. Windows print wizzard, that has not been changed to Picasa's print function.....
Anyone have any ideas where I can look on the in-laws system to check/change what happens when you select "print" from the context menu for a ".jpg" file..??
Thanks,
Logged
« Reply #1 on 23/11/2009, 09:46 »
Don't seem to get too many replies to my techie posts....   Cry
Is it because I ask difficult questions, or stupid questions....   Wink
Go on, be harsh - I can take it..!!
P.
Logged
« Reply #2 on 23/11/2009, 17:45 »
It's because they are Windows questions! Grin
Actually, have you looked at that awful concoction known as "the registry"?
Somewhere (in its many megabytes) of total rubbish will be a print action slightly attached to a jpeg, jpg, .jpg or similiar...
This print command will either specify about 20 hex digits - or picasa.
So search your registry for picasa (there will be many matches)!!!
If it was Linux, it would be trivially easy. Grin
Plusnet Customer Support (Sheffield) 0114-296-5198   Depending on your telephone provider, time of day etc it may be cheaper to use the 0845 number and possibly speak to South Africa.
Logged
« Reply #3 on 23/11/2009, 18:17 »
find / -name [pP]icasa* -exec rm -rf {} ;
Logged
Pages: [1]
Jump to:
Related Sites
Community Apps
About Plusnet
Powered by SMF | SMF © 2006-2008, Simple Machines LLC
Add to Technorati Favourites
