Saturday 21st November 2009Login | Register | Help
Pages: [1]
Moving to new premium
« on 07/11/2009, 11:33 »
Hi
I have been on Prem op 1 for quite a while now and it has served me well but I now need to look at another package which removes the download limit at peak times.  Will i notice much difference between the two as My son has X box live and is now starting to use the sky player on it as well.
Any ideas
Craig P
Logged
« Reply #1 on 07/11/2009, 13:39 »
Craig, looks like you are in the same situation as me. See 'Where do I go from here' post.
Premium gives 80GB but quite a few things have very restricted speeds at peak times.
Andy
Logged
« Reply #2 on 07/11/2009, 14:18 »
Wow Andy
Its just like looking in a mirror Cheesy.  I know what you mean re usage.  Since Sky player came out on X Box,  son no 1 used 2.5 gig in 3 days but said he new nothing about it.  Its stopped since we "had a chat" hahaha Hes 16.5 so a few grunts later and all was good   I dont know which way to go but my monthly usage remains below 30 gig at the mo but I only download after
12.00 am. Its the 8.00 am time scale i would miss but the extra usage would more than make up for that I think.  I also think that you can change back to your old package within a month if the new one is not working for you but im sure I will be corrected if im wrong  As long as online gaming is ok then I think that this might be the way to go.
Craig P
Logged
« Reply #3 on 07/11/2009, 14:24 »
generally yes you can move back within the month
Free-online member since 15 Dec 1998
You dont have to be mad to understand what PN are up to, but it helps
Logged
  • ASBO DOG
  • Bright Spark
  • Monk or Mugger?
  • View Profile
« Reply #4 on 07/11/2009, 16:38 »
        Plusnet community collaborative spotify playlist, add your tracks here -->
Logged
« Reply #5 on 07/11/2009, 17:49 »
Hi
ive had a look at that and can't see how its going to affect me much.  Just got to be brave to take the leap.
P
Logged
  • orbrey
  • Plusnet Staff
  • The Bagger 288 is coming. Look busy.
  • View Profile
« Reply #6 on 09/11/2009, 11:35 »
Hi Craig,
If you move to the new product and it doesn't work out for you drop me a PM - as long as it's within the first month I'd be happy to move you back.
« Reply #7 on 10/11/2009, 09:17 »
Hi orbrey
I  moved yesterday to the new premium package and it said it should change on my next billing date of 02/12/2009.  Will the month start from them and will I see much differance on X box live?
KR
craig
Logged
  • Jameseh
  • Legend
  • Napier for England!
  • View Profile
« Reply #8 on 10/11/2009, 14:48 »
Hi Craig,
Yes, your month should start from then.
From my perspective, you shouldn't notice a massive difference on XBOX Live, although your downloads should be quicker.
twitter / Jameseh
Logged
Pages: [1]
Jump to:
Related Sites
Community Apps
About Plusnet
Powered by SMF | SMF © 2006-2008, Simple Machines LLC
Add to Technorati Favourites
