Sunday 22nd November 2009Login | Register | Help
Pages: [1]
Have I been punished?
  • Zap
  • View Profile
« on 07/11/2009, 10:52 »
I am not a leech, I hardly ever download big files, but one thing that is precious to me is my Pure Evoke Flow internet radio.
For some reason this keeps cutting out and yet it works fine at another location.
I can see nothing wrong with my wireless router so I am wondering such traffic has been "shaped" by plusnet into being unusable?
I get about 20 seconds of radio then no volume, wireless signal is at maximum.
No other devices using the internet.
My usage so far this month is just 9gb out of 16gb which must last till the 22nd.  This is higher than usual as I have downloaded a few demos and a WEBEX training course for a piece of software I have to learn.
Just wondering if Plusnet has made any changes to to shaping as speedtest.net shows
If my traffic was being restricted is there a page on the member centre that can tell me?
Logged
« Reply #1 on 07/11/2009, 10:57 »
Please check what your current line speed is set at here: https://portal.plus.net/m...ction=data_transfer_speed just in case your profile is low for some reason.
Logged
  • Zap
  • View Profile
« Reply #2 on 07/11/2009, 10:59 »
Thanks for reply,  Link says it is fine:
Estimated line speed:
    Not recorded (service activated before we introduced estimates).
Current line speed:
    7000
Logged
« Reply #3 on 07/11/2009, 11:49 »
as you did not tell us your package and times have a look here http://www.kitz.co.uk/isp/plusnet_shaping.htm
Free-online member since 15 Dec 1998
You dont have to be mad to understand what PN are up to, but it helps
Logged
« Reply #4 on 07/11/2009, 16:21 »
Surely your internet radio uses streaming traffic?  This should run at line speed on all packages at all times, shouldn't it?
Logged
  • adiewoo
  • Forum Moderator
  • My avatar has left the building :(
  • View Profile
« Reply #5 on 07/11/2009, 16:26 »
Unless it's BB+ which doesn't prioritise streaming traffic, though not sure what PN package has ever had a 16GB cap.
Forum Moderator and customer - plusnet Unlimited - March '09 plusnet Premier Option 1 - August '03 - March '09
PUG IRC - http://usertools.plus.net/irc/ - usertools.plus.net:6667, Channel #Usertools.
Logged
« Reply #6 on 07/11/2009, 16:29 »
Presumably that 16GB includes some paid-for top-up?
Logged
  • orbrey
  • Plusnet Staff
  • The Bagger 288 is coming. Look busy.
  • View Profile
« Reply #7 on 09/11/2009, 10:32 »
Hi Zap,
In this case I'd recommend a wireshark capture - if you follow the guide but instead of downloading the file start your radio stream instead, that will capture the packets from the radio stream. You'll then be able to see what priority they're assigned, and if it's not in gold submit a ticket with the wireshark pcap file attached. We'll be able to make sure that it gets added for you.
Hope that helps,
Pages: [1]
Jump to:
Related Sites
Community Apps
About Plusnet
Powered by SMF | SMF © 2006-2008, Simple Machines LLC
Add to Technorati Favourites
