Sunday 22nd November 2009Login | Register | Help
Pages: [1] 2
Errors (Dont look James :P)
« on 07/11/2009, 01:36 »
James told me I should have interleaving on because he was seeing alot of errors in my connection but I really dont want it on  Tongue
I just want to compare to others really, to see if this is normal or not. Although I dont fully understand what each of these error types mean..
(And no I havent had any problems with my connection recently)
Simply just curious.
Uptime:   0 days, 6:36:13
Loss of Framing (Local/Remote):   24 / 0
Loss of Signal (Local/Remote):   2 / 0
Loss of Power (Local/Remote):   0 / 0
Loss of Link (Remote):   0
Error Seconds (Local/Remote):   46 / 0
FEC Errors (Up/Down):   0 / 0
CRC Errors (Up/Down):   3 / 769
HEC Errors (Up/Down):   1 / 143
Please post yours so I can compare Smiley
Logged
« Reply #1 on 07/11/2009, 01:52 »
Saw on dslreport forum they like to see errors after 2 minutes, apparently easier to judge, so heres mine after 2 minutes
Uptime:   0 days, 0:03:19
Loss of Framing (Local/Remote):   0 / 0
Loss of Signal (Local/Remote):   0 / 0
Error Seconds (Local/Remote):   0 / 0
CRC Errors (Up/Down):   0 / 1
HEC Errors (Up/Down):   0 / 1
Logged
  • ASBO DOG
  • Bright Spark
  • Monk or Mugger?
  • View Profile
« Reply #2 on 07/11/2009, 02:07 »
the upstream errors are a random reporting bug i got for some reason last time i resync'ed.
i run at a max of 250 es aday on fastpath and apart from the 21cn DLM puting me on a band i never had issues running fastpath on 20cn and currently dont on 21cn touch wood since i got un banded.
i would never have interleaving even at my line length unless i was getting lots an lots  of resync's or insane error counts that was effecting throughput
what router do you have?
on my switch over from 20cn to 21cn adsl2 my fastpath was kept on so ive never had interleaving on since being on adsl2 last april.
still unknowen if james knew i would be asking for fastpath when he placed my order or if it was just the settings ported over from 20cn as my line synced with same noise margin ect as soon as adsl2+ came live on my line
« Last Edit: 07/11/2009, 02:22 by ASBO DOG »
        Plusnet community collaborative spotify playlist, add your tracks here -->
Logged
« Reply #3 on 07/11/2009, 03:02 »
Im using the Thomson from Plusnet, TG585 v7.
Well so far so good I guess, aslong as its normal to get some errors Im happy Smiley
Logged
  • Jameseh
  • Legend
  • Napier for England!
  • View Profile
« Reply #4 on 07/11/2009, 03:04 »
I knew you wanted interleaving turned off Wink
Default is auto, I turned it off.
twitter / Jameseh
Logged
  • ASBO DOG
  • Bright Spark
  • Monk or Mugger?
  • View Profile
« Reply #5 on 07/11/2009, 04:00 »
lower error's the better but as for my error rates on my line i dont see them effect me at all (unless there is a lighting storm then they raise very quickly and get the DLM hot and botherd but thats not very often so i can live with that)
james did you find 1st gear on FM3 or did you just keep to you fav reverse gear  Smiley
« Last Edit: 07/11/2009, 04:02 by ASBO DOG »
Logged
  • nadger
  • Usergroup Member
  • View Profile WWW
« Reply #6 on 07/11/2009, 09:07 »
I get massive error numbers and have given up worrying about them as connection is stable and don't see any other problems.
Uptime:   30 days, 1:10:27
Loss of Signal (Local/Remote):   1 / 0
Error Seconds (Local/Remote):   2,213 / 0
FEC Errors (Up/Down):   0 / 897,487,482
CRC Errors (Up/Down):   0 / 91,592
HEC Errors (Up/Down):   0 / 72,774
Logged
  • Strat
  • Forum Moderator
  • View Profile
« Reply #7 on 07/11/2009, 11:29 »
Mine are below.
Plusnet Customer and Forum Moderator  Which gateway am I on and How is it Performing (Scroll down to your Gateway Graph)
Acronyms are a PITA
Logged
« Reply #8 on 07/11/2009, 11:43 »
I don't think my router knows what an error is!
Logged
« Reply #9 on 07/11/2009, 11:47 »
Shocked as if  Tongue
Logged
« Reply #10 on 07/11/2009, 11:55 »
I suspect, mabe my router might possibly be lying.
Honestly I guess it is failing to read or report any errors, been like that for a long time, even tried the factory reset button.
It does make me wonder if any of the other information it's giving me can be trusted.
My line is NOT super stable.
Think I might need to dig out the old BT 210.
(anyone want to buy an 'ERROR FREE' router? Grin)
Logged
« Reply #11 on 07/11/2009, 13:32 »
There's no way I'll be turning off interleaving any time soon!
Quote from: Bob's router
   Link Information
Uptime:   3 days, 0:28:13
DSL Type:   G.992.1 annex A
Bandwidth (Up/Down) [kbps/kbps]:   832 / 6,752
Data Transferred (Sent/Received) [kB/kB]:   0.00 / 0.00
Output Power (Up/Down) [dBm]:   11.5 / 19.5
Line Attenuation (Up/Down) [dB]:   23.0 / 36.0
SN Margin (Up/Down) [dB]:   9.0 / 5.5
Vendor ID (Local/Remote):   TMMB / ALCB
FEC Errors (Up/Down):   115 / 556,427,193
CRC Errors (Up/Down):   115 / 69
HEC Errors (Up/Down):   71 / 58
Plusnet Comms Team
Service Status :: RSS :: Email
twitter / plusnet
Logged
  • nadger
  • Usergroup Member
  • View Profile WWW
« Reply #12 on 07/11/2009, 16:00 »
Would that be a Thomson SpeedTouch as well, Bob? Looks like it from stats.
I've heard that they show high error figures and my two certainly do despite connection being stable.
Logged
« Reply #13 on 07/11/2009, 16:21 »
Yeah it is, I get similar results with my 2wire as well though.
Plusnet Comms Team
twitter / plusnet
Logged
  • ASBO DOG
  • Bright Spark
  • Monk or Mugger?
  • View Profile
« Reply #14 on 07/11/2009, 16:29 »
the thomson reporting bug gives these
FEC Errors (Up/Down): 4,294,967,264 / 0
CRC Errors (Up/Down): 4,294,967,264 / 10
Logged
  • Anotherone
  • Bright Spark
  • Occasionally Bright, brain slower than it was.....
  • View Profile
« Reply #15 on 07/11/2009, 16:39 »
Yes those 585v7's seem to report erroneous FEC error figures judging by a wide assortment of posts on these boards. Only just read this thread (so the PS in by PM to you Bob has been answered!)
The CRC errors that have been posted are within acceptable limits based on guidelines I've seen, although I can't comment specifically on Dick's (no uptime showing). 120 or so per hour isn't so bad, nice if it's lower. ASBO's DS figures (reply #2) are quite respectable for a longer line.
Regards, Chris (Anotherone) alias Alex Bell (courtesy ASBO DOG). You can phone PN CSC Sheffield on 0114-296-5198 NB this is normally a chargeable call dependant on your package
New Moderators - This is what I said
My brain is running at  0x60 today, but this site seems much worse
Logged
Pages: [1] 2
Jump to:
Related Sites
Community Apps
About Plusnet
Powered by SMF | SMF © 2006-2008, Simple Machines LLC
Add to Technorati Favourites
