Sunday 22nd November 2009Login | Register | Help
Pages: [1]
Setting up Webspace - Assistance Please
« on 04/11/2009, 09:11 »
Hi  All, I have put together a simple website using Kompozer and have tried to publish this to my Plusnet webspace but without success.
I have tried to follow the instruction on the website but must be doing something wrong.
In Kompozer I have set the following details in
Website Information: http://www.username.plus.com
Publishing Server: ftp://ftp.plus.net/htdocs
User name: myusename
password: my password
Any assistance/guidance greatly appreciated
Thanks Dave
Logged
  • jelv
  • Bright Spark
  • View Profile
« Reply #1 on 04/11/2009, 09:30 »
The publishing server doesn't have the /htdocs on the end. htdocs is the name of the folder to which you have to upload the content once the ftp connection is established.
jelv
Plusnet chatroom: /server usertools.plus.net   /join #usertools
Plusnet Unlimited is not without limits
Logged
« Reply #2 on 04/11/2009, 10:53 »
I'm on FOL, but I would imagine the process is the same.  I publish to  ftp://homepages.free-online.net/htdocs
Logged
  • Midnight Caller
  • Please remember that I am Dyslexic wen replying
  • View Profile WWW
« Reply #3 on 04/11/2009, 12:48 »
or you can do it this way in your Browser for eggzampull Internet Explorer v6 put in to the Address bar: ftp://Username:your_password@ftp.plus.net/htdocs/
Kind Regards, Gary Lambert.      Force9 ID: dyslexia,
PlusNet ID: tdadyslexia,     PlusNet Since 6 Febuary 2001
DHEA Community Forum        Pleas Help Me To Save Lives
Logged
« Reply #4 on 04/11/2009, 14:41 »
Thanks for your replies.
I have tried different things and have now progressed slightly. I have published the site but if i try and view the site it now get:
Index of /
Parent Directory
Index.html
this shows in IE when i try and go to the site.
Any ideas?  Thanks
Logged
  • Midnight Caller
  • View Profile WWW
« Reply #5 on 05/11/2009, 07:26 »
You must have your first page called: index.html
Plus you should have it in lower case,  do not use upper case for your file extensions.
Can you give us a link to your site?
Logged
  • orbrey
  • Plusnet Staff
  • The Bagger 288 is coming. Look busy.
  • View Profile
« Reply #6 on 06/11/2009, 15:34 »
Hi Dave,
I've taken the liberty of logging in to your webspace and renaming the index.html file as per Gary's advice above (thanks Gary). The issue was indeed that you'd capitalised the I on index.
You should now see the correct page when you browse to your site.
Hope that helps,
Pages: [1]
Jump to:
Related Sites
Community Apps
About Plusnet
Powered by SMF | SMF © 2006-2008, Simple Machines LLC
Add to Technorati Favourites
