Monday 22nd March 2010Login | Register | Help
Pages: [1]
Forced to reload tabs?
« on 31/10/2009, 11:47 »
Firefox latest version; XP Home SP3; Avast Aniyirus (free); ZA free fiewall; Nefgear rouer firewall.
I am seeing substantially more incidences of a file appearing to have loaded in FF, i.e. the loading sign is not visible and the name visible, but without anything coming up on screen. When I reload the tab, the expected screen loads successfully.
I also think that when I try to access a link within files/sites on view or from a search, there are more times of "this link appears ti be broken" than I'd expect.
Suggestions wanted.
Logged
« Reply #1 on 31/10/2009, 12:03 »
dns ?
Logged
« Reply #2 on 31/10/2009, 15:00 »
?? but there seem so many unlikely to be connected instances.
Can you go further with reply?
[Moderator's note by Dick (Strat):  Full quote of preceding post removed, as per Forum Rules ]
« Last Edit: 31/10/2009, 18:11 by Strat »
Logged
« Reply #3 on 31/10/2009, 15:34 »
I'm interested in your question as I am experiencing a similar problem with Firefox.  No problem with IE though.
Wake Up and Smell the Coffee!!
Logged
« Reply #4 on 31/10/2009, 18:59 »
I think I may have cracked it. I found a link that refered to the problem, but lost the link Embarrassed
Anyhow in essence it seemed to point to the firewalls' program access controls in Firewalls needing resetting after (in my case) a new FF version being installed. ZA was especially mentioned.
Logged
« Reply #5 on 31/10/2009, 21:19 »
Thanks for that.  I've only use the PN firewall and the router built-in one.  I have reset them and it seems to have done the trick.  Thank you.
Logged
  • Chris
  • Plusnet Staff
  • View Profile
« Reply #6 on 02/11/2009, 12:52 »
We did have some reported issues with DNS last night, which may have compounded this. Glad to hear you've found the main cause and how to fix it though.
Chris Parr
Plusnet Support Team
Service Status :: RSS :: Email
twitter / plusnet
Logged
« Reply #7 on 02/11/2009, 13:38 »
What more is there to do? Smiley
Logged
Pages: [1]
Jump to:
Related Sites
Community Apps
About Plusnet
Powered by SMF | SMF © 2006-2008, Simple Machines LLC
Add to Technorati Favourites
