Sunday 22nd November 2009Login | Register | Help
Pages: [1]
VMBU not registering usage
« on 29/10/2009, 21:04 »
My VMBU isn;t showing any usage over the last  24 hours ...
anyone else  seeing similar?
Logged
« Reply #1 on 29/10/2009, 21:15 »
No problem with mine, showing downloads made within a couple of hours
Logged
  • Jameseh
  • Legend
  • Napier for England!
  • View Profile
« Reply #2 on 30/10/2009, 11:10 »
Paul,
It's possible that that's related to the change that we made for you.
Did it also do the same when I did it previously?
twitter / Jameseh
Logged
« Reply #3 on 30/10/2009, 12:34 »
nope, all the previous changes simply reset it to a new start of month the day the change went through., like this:
Code:
Billing Period Peak usage Off-peak usage Total usage
14 Oct - 14 Oct  135.62MB 0KB 135.62MB
15 Oct - 23 Oct  1.15GB 332.67MB 1.48GB
24 Oct - 26 Oct  218.84MB 243.19MB 462.03MB
this time it's just stopped registering after 0800 wednesday 28th
Logged
  • Jameseh
  • Legend
  • View Profile
« Reply #4 on 30/10/2009, 12:42 »
I'll check with Dave.
See if he did something differently to how I did it.
twitter / Jameseh
Logged
« Reply #5 on 31/10/2009, 09:57 »
Still showing nil usage.
Should I raise this as a ticket?
Logged
« Reply #6 on 01/11/2009, 12:48 »
Raised as a ticket 30571256
Logged
  • Mand
  • Plusnet Staff
  • You live and learn. At any rate, you live.
  • View Profile
« Reply #7 on 02/11/2009, 14:36 »
Your VMBU appears to be showing some usage now?
« Reply #8 on 02/11/2009, 17:57 »
yep
does that coincide with the disconnect I wonder ...
Logged
  • orbrey
  • Plusnet Staff
  • The Bagger 288 is coming. Look busy.
  • View Profile
« Reply #9 on 03/11/2009, 10:32 »
It will have done, I suspect the IP you were connected on wasn't authed against the traffic management platform but this was fixed when you reconnected - hence the usage being collected now.
« Reply #10 on 03/11/2009, 20:29 »
that's interesting  ... so my IP at that stage was "wild"  so to speak  ... does that mean that my usage wasn't registered at all and therefore has slipped through the net? Or has been counted but I just can't see it?
Logged
  • Mand
  • Plusnet Staff
  • View Profile
« Reply #11 on 04/11/2009, 13:17 »
It won't have been counted.
Lucky you Wink
« Reply #12 on 04/11/2009, 14:12 »
and it's nice to think that IP hs been released back into the wild, and can once again roam the wide open savannahs of the interweb free and untamed
Logged
Pages: [1]
Jump to:
Related Sites
Community Apps
About Plusnet
Powered by SMF | SMF © 2006-2008, Simple Machines LLC
Add to Technorati Favourites
