Sunday 21st March 2010Login | Register | Help
Pages: 1 ... 3 4 [5]
Dead monitor, repair or replace
  • MrC
  • View Profile
« Reply #64 on 15/11/2009, 21:05 »
I like widescreen but only when it is used properly for imagery which was designed for it. Anything else should naturally be on a normal square screen for which it was probably made for.
I think (but am prepared to be corrected Smiley ) that most TV programmes have for some time been recorded/transmitted in 16:9 and that 4:3 TVs actually chop off a bit of the picture. Obviously older stuff recorded in 4:3 will have to be mangled to fit a 16:9 screen.
Logged
« Reply #65 on 15/11/2009, 23:31 »
Santiago: Have you tried contacting Bolton trading standards yet?
http://www.bolton.gov.uk/...dingstandards.aspx?bid=46
No I didn't. I only called Scan on Saturday. I will contact trading standards during the week. Thanks for the link.
twitter / beeare
Logged
« Reply #66 on 16/11/2009, 07:56 »
I know of at least one program that is still transmitted live in 4.3 standard
Free-online member since 15 Dec 1998
You dont have to be mad to understand what PN are up to, but it helps
Logged
« Reply #67 on 16/11/2009, 08:00 »
family guy on bbc3 is pumped out at 4:3 and i belive i think most of itv4 if not there is one channel on the freeview line up that seems to be all in 4:3
XBL gamertag= scootie uk
Logged
« Reply #68 on 16/11/2009, 08:05 »
my one is Ideal World Shopping channel, do not buy anything but wife likes the craft demos, chose freeview or freesat
« Last Edit: 16/11/2009, 08:07 by pierre_pierre »
Logged
« Reply #69 on 16/11/2009, 08:11 »
am currently using a sky box with out card and any freeview/free to air channels that dont unlock in the skys tvguide i just find the settings for the channel and add them manualy. only downside is you have to go to other channels to sselect them and theres no tvguide for them.
i use tvcatchup on any tv /monitors that are under 20inch, thoe when they get round to adding a choice of higher Q streams i may be be able to use tvcatchup through out the house
Logged
« Reply #70 on 30/11/2009, 11:52 »
Because wide screen stretches the real picture unless it is specifically designed for it (ie with the black stripe at the top and bottom so that the picture can be enlarged).
I believe there are options in both Nvidia and ATi driver bundles where you can set the aspect ratio so that a 4:3 picture will display as 4:3 with black bars down the side. Also a lot of newer games support wide-screen output don't they?
Logged
Jump to:
Related Sites
Community Apps
About Plusnet
Powered by SMF | SMF © 2006-2008, Simple Machines LLC
Add to Technorati Favourites
