Saturday 21st November 2009Login | Register | Help
Pages: [1] 2 3 4
Call data problem?
« on 14/10/2009, 11:18 »
Hi
I made a couple of calls to New Zeland night from around 10 pm last night, i logged into my account  about 20 mins ago expecting the remaining minutes to reflect this , but it still say i have 300 remaining, is there a problem with call data as this should be updated every 4 hrs ?
Regards Mike
[Moderator's note by Thomas (Be3G): thread moved to more appropriate location, and title edited to remove now-unecessary duplication.]
« Last Edit: 14/10/2009, 20:24 by Be3G »
  • Jameseh
  • Legend
  • Napier for England!
  • View Profile
« Reply #1 on 14/10/2009, 11:23 »
I'd give it 24 hours first.
Are you able to see the call in the call records itself?
twitter / Jameseh
Logged
« Reply #2 on 14/10/2009, 11:41 »
Hi James
I can not see the call in call records (my call records is blank)
Can i ask are all types calls meant to be listed in recent calls/ call summary ?
At the moment i have only made calls to landlines at evening and weekends, and the top 20 destinations at evenings, recent calls and call summary say i have made no calls , i assume when they are free they are not counted?
Regards Mike
« Last Edit: 14/10/2009, 11:43 by ITWorks »
  • Jameseh
  • Legend
  • View Profile
« Reply #3 on 14/10/2009, 11:44 »
Mike,
PM me the username you're referring to and I'll double check.
twitter / Jameseh
Logged
« Reply #4 on 14/10/2009, 11:47 »
Done Smiley
« Reply #5 on 14/10/2009, 11:49 »
all calls are listed free and paid, but sa james says,  since the recent bog up it can be 24 or even 48 hours before they show up.  They used to show a uconfirmed after 4 hours, but now only show unconfirmed.
@James.  are the 0845 calls to support completely free, i.e dont come off my allowance?  - Legacy 240
Free-online member since 15 Dec 1998
You dont have to be mad to understand what PN are up to, but it helps
Logged
  • Jameseh
  • Legend
  • View Profile
« Reply #6 on 14/10/2009, 11:50 »
Yes Peter.
twitter / Jameseh
Logged
« Reply #7 on 14/10/2009, 11:58 »
There must be a problem on my account then as i have made a few calls ( all free so far) in the past two weeks since my move over and nothing is showing , all my recent calls are blank so is call summary
Regards Mike
« Last Edit: 14/10/2009, 12:00 by ITWorks »
« Reply #8 on 14/10/2009, 12:00 »
The reason I asked was that 0800, 0500 calls dont show bot one I tried to make the other day shows on my data as an 11 minute call (got fed up waiting) but just checked not on the itemised bill
Logged
  • Jameseh
  • Legend
  • View Profile
« Reply #9 on 14/10/2009, 12:41 »
Mike,
As per Peter's post, are these calls to non 0500/0800 numbers?
As those would not show up.
twitter / Jameseh
Logged
« Reply #10 on 14/10/2009, 13:02 »
The calls i have made have been to 01 , 02 numbers , which should be showing ?
Regards
Mike
  • Jameseh
  • Legend
  • View Profile
« Reply #11 on 14/10/2009, 13:04 »
Yep, sounds like a problem then.
twitter / Jameseh
Logged
« Reply #12 on 14/10/2009, 13:23 »
i will give support a ring
  • Jameseh
  • Legend
  • View Profile
« Reply #13 on 14/10/2009, 13:25 »
You already have.
Leave it with me.
twitter / Jameseh
Logged
  • Jameseh
  • Legend
  • View Profile
« Reply #14 on 14/10/2009, 13:33 »
Should catch up in the next 24 hours Mike.
You've made 12 calls.
twitter / Jameseh
Logged
« Reply #15 on 14/10/2009, 13:41 »
Thanks James
Pages: [1] 2 3 4
Jump to:
Related Sites
Community Apps
About Plusnet
Powered by SMF | SMF © 2006-2008, Simple Machines LLC
Add to Technorati Favourites
