I'm hoping you can point me in the right direction in setting this phone up.
I do think that between plusnet and siemens they have made this so difficult. From the voip.plus.net portal I have obtained my 7 digit extension number, the sip server (sip2.plus.net), re-entered the password (just to make sure it is the password for voip phone and not the portal), and pressed the SAVE button.
This is what I've been entering:
Authentication Name: my 7 digit extension number beginning with 4
Authentication password: as entered on the voip.plus.net website
Username: my 7 digit extension number beginning with 4
Display name: anytext
General Provider Data
Domain: sip2.plus.net
Proxy server address: sip2.plus.net
Proxy server port: 5060
Registrar server: sip2.plus.net
Registrar server port: 5060
Registration refresh time: 180sec
Network
STUN enabled: No
STUN server:
STUN port: 3478
STUN refresh time: 240 sec
NAT refresh time: 20 sec
Outbound proxy mode: Always
Outbound proxy: nat.plus.net
Outbound proxy port: 5082
On entering the data I press the set button and it always comes up with 'Registration failed'. I've tried using sip.plus.net and also newsip.plus.net for the Domain, Proxy server and registration server to no avail.
The phone is working fine on fixed line and the gigaset voip, so I'm pretty sure its not a phone issue.
Any help would sure be appreciated.
