Sunday 21st March 2010Login | Register | Help
Pages: [1] 2 3 ... 5
Inbound calls diverted to voicemail
« on 17/06/2009, 11:26 »
Well I made a little more progress. Silly me - I was putting in the default PIN of the GAP phone and not the PIN which I set the base station up with.
I corrected this and thought it was OK. The GAP handset said HS-2 for a few moments. However, I have now lost dial tone on both handsets (note I'm only using this for VOIP so no fixed line attached) but also, when I ring the geographic number, my phone is tied up and I go straight to Plusnet's voicemail system.  don't know how to unengage the VOIP.
Please can someone help.
Logged
« Reply #1 on 17/06/2009, 11:50 »
Just an additional note on to the above - strangely, I can dial out but not in.
Logged
  • adiewoo
  • Forum Moderator
  • View Profile
« Reply #2 on 17/06/2009, 11:53 »
Is it showing as registered at voip.plus.net?
Forum Moderator and customer - plusnet Unlimited - March '09 plusnet Premier Option 1 - August '03 - March '09
PUG IRC - http://usertools.plus.net/irc/ - usertools.plus.net:6667, Channel #Usertools.
Logged
« Reply #3 on 17/06/2009, 12:04 »
Sorry for being a bit slow but where do I look to check this please?
Logged
  • adiewoo
  • Forum Moderator
  • View Profile
« Reply #4 on 17/06/2009, 12:07 »
If you sign on here https://voip.plus.net/login/ under account overview what does it say?
Logged
« Reply #5 on 17/06/2009, 12:08 »
Broadband Phone 120 2009-03-06 12:25:42 01752 ****** ******* (Ext) online until 2009-06-17 12:09:40
Where I have put asterisks, it shows my geographic number and my sip extension.
Logged
  • adiewoo
  • Forum Moderator
  • View Profile
« Reply #6 on 17/06/2009, 12:11 »
So that's looking OK.. if you de-register the new handset does the dial tone come back?
Logged
« Reply #7 on 17/06/2009, 14:20 »
Hi again. No, I have deregistered the additional handset and still no joy. I have even set the original handset back to default settings but this has not helped.
Logged
  • adiewoo
  • Forum Moderator
  • View Profile
« Reply #8 on 17/06/2009, 15:06 »
It might not be you, I've just been told all my calls are diverting too.
Logged
  • adiewoo
  • Forum Moderator
  • View Profile
« Reply #9 on 17/06/2009, 15:07 »
Just tested it and it does.
Logged
  • Jameseh
  • Plusnet Staff
  • Napier for England!
  • View Profile
« Reply #10 on 17/06/2009, 15:22 »
Guys,
I've just done the equivalent of "refreshing" your VoIP service.
Can you try again in 45 minutes and see if your calls are going through?
James Bailey
Plusnet New Recruits and Advisor Graduation Lead
Service Status || RSS
Logged
« Reply #11 on 17/06/2009, 15:25 »
Will do. Annie
Logged
  • adiewoo
  • Forum Moderator
  • View Profile
« Reply #12 on 17/06/2009, 15:26 »
thanks James, will do.
Logged
  • Jameseh
  • Plusnet Staff
  • View Profile
« Reply #13 on 17/06/2009, 15:27 »
Thanks.
There's only so many times I can listen to Adie's voicemail Wink
James Bailey
Logged
« Reply #14 on 17/06/2009, 16:08 »
@Annie,
If that doesnt work, I'd try a reset of the C475. You can do it from the web configurator or by powering off and on. It should retain all the settings ( including handset registrations ) across the reset.
Logged
  • Jameseh
  • Plusnet Staff
  • View Profile
« Reply #15 on 17/06/2009, 16:16 »
Annie & Adie
I've just tried calling you both and get diverted straight to voicemail.
We're raising this to Gradwell now.
James Bailey
Logged
Jump to:
Related Sites
Community Apps
About Plusnet
Powered by SMF | SMF © 2006-2008, Simple Machines LLC
Add to Technorati Favourites
