Instability of 21CN and ADSL2+
- Instability of 21CN and ADSL2+
13-05-2009 9:12 PM
Re: Instability of 21CN and ADSL2+
14-05-2009 10:30 AM
My ADSL2+ LLU line is a long way from being stable
14-05-2009 11:03 AM
Quote from: Jameseh My ADSL2+ LLU line is a long way from being stable
But does it instantly adapt to current line conditions (without the equivalent of IP Profile)?
14-05-2009 11:19 AM
It was fine @ 3dB. then my line got noisier and would drop every 5 minutes. Had to request an increase to 6dB and now it drops about 5 times a day. I could request a few increase to improve stability if I could be bothered.
(I'm permanantly connected to the test socket which seems to offer a slightly better level of stability than the iplate.)
14-05-2009 2:30 PM
3Mb FTTC
14-05-2009 2:31 PM
14-05-2009 2:35 PM
If you are getting constant SNR and seeing your line speed go up and down a bit, that is how SRA works.
3Mb FTTC
14-05-2009 2:37 PM
14-05-2009 2:39 PM
Quote then my line got noisier and would drop every 5 minutes
that would not stand up in court as being seamless.
beat me to it jimbo
14-05-2009 8:44 PM
Current router logs look terrible
May 14 19:38:25 LOGOUT User logged out on TELNET (192.168.1.4)
Info May 14 19:37:33 LOGIN User logged in on TELNET (192.168.1.4)
Info May 14 19:01:37 FIREWALL event (1 of 1): deleted rules
Info May 14 19:01:37 GRP Default destination is routed via gateway 80.229.156.222
Warning May 14 19:01:37 PPP link up (Internet) [80.229.156.222]
Info May 14 19:01:37 PPP CHAP Chap receive success : authentication ok
Info May 14 19:01:37 PPP CHAP Receive challenge (rhost = THN-AG2)
Info May 14 19:01:37 PPP CHAP Receive challenge (rhost = bras-red1.pr)
Info May 14 19:01:29 xDSL linestate up (ITU-T G.992.5; downstream: 5888 kbit/s, upstream: 601 kbit/s; output Power Down: 20.0 dBm, Up: 13.0 dBm; line Attenuation Down: 44.5 dB, Up: 24.5 dB; snr Margin Down: 6.0 dB, Up: 6.5 dB)
Info May 14 19:01:05 xDSL linestate down
Info May 14 19:00:39 xDSL linestate down
Info May 14 19:00:25 xDSL linestate down
Info May 14 19:00:01 xDSL linestate up (ITU-T G.992.5; downstream: 5899 kbit/s, upstream: 718 kbit/s; output Power Down: 20.0 dBm, Up: 12.5 dBm; line Attenuation Down: 44.5 dB, Up: 24.5 dB; snr Margin Down: 6.0 dB, Up: 6.5 dB)
Warning May 14 19:00:00 PPP link down (Internet) [80.229.156.222]
Info May 14 18:59:35 xDSL linestate down
Info May 14 18:59:16 FIREWALL event (1 of 1): created rules
Info May 14 18:59:15 GRP Default destination is not routed anymore via gateway 80.229.156.222
Info May 14 18:59:15 xDSL linestate down
Info May 14 18:58:40 FIREWALL event (1 of 1): deleted rules
Info May 14 18:58:40 GRP Default destination is routed via gateway 80.229.156.222
Warning May 14 18:58:40 PPP link up (Internet) [80.229.156.222]
Info May 14 18:58:40 PPP CHAP Chap receive success : authentication ok
Info May 14 18:58:39 PPP CHAP Receive challenge (rhost = THN-AG2)
Info May 14 18:58:39 PPP CHAP Receive challenge (rhost = bras-red1.pr)
Info May 14 18:58:28 xDSL linestate up (ITU-T G.992.5; downstream: 5942 kbit/s, upstream: 999 kbit/s; output Power Down: 20.0 dBm, Up: 12.5 dBm; line Attenuation Down: 44.0 dB, Up: 24.0 dB; snr Margin Down: 6.0 dB, Up: 6.5 dB)
Warning May 14 18:58:23 PPP link down (Internet) [80.229.156.222]
Info May 14 18:58:03 xDSL linestate down
Info May 14 18:57:37 FIREWALL event (1 of 1): created rules
Info May 14 18:57:38 GRP Default destination is not routed anymore via gateway 80.229.156.222
Info May 14 18:57:38 xDSL linestate down
Info May 14 18:56:33 FIREWALL event (1 of 1): deleted rules
Info May 14 18:56:32 GRP Default destination is routed via gateway 80.229.156.222
Warning May 14 18:56:33 PPP link up (Internet) [80.229.156.222]
Info May 14 18:56:33 PPP CHAP Chap receive success : authentication ok
Info May 14 18:56:33 PPP CHAP Receive challenge (rhost = THN-AG2)
Info May 14 18:56:32 PPP CHAP Receive challenge (rhost = bras-red1.pr)
Info May 14 18:56:28 xDSL linestate up (ITU-T G.992.5; downstream: 4724 kbit/s, upstream: 89 kbit/s; output Power Down: 19.5 dBm, Up: 11.5 dBm; line Attenuation Down: 46.5 dB, Up: 26.0 dB; snr Margin Down: 6.0 dB, Up: 6.0 dB)
Warning May 14 18:56:04 PPP link down (Internet) [80.229.156.222]
Info May 14 18:56:02 xDSL linestate down
15-05-2009 11:28 AM
Have you tried raising a fault to the CSC?
Your connection shouldn't be seeing that level of instability, trial or no trial.
15-05-2009 7:55 PM
Chris
16-05-2009 8:16 PM
May 16 18:43:19 SNTP Synchronised to server: 212.159.13.49
Info May 16 17:43:19 SNTP Synchronised again to server: 212.159.6.9
Info May 16 16:43:19 SNTP Synchronised to server: 212.159.6.9
Error May 16 16:29:10 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 216.114.66.158 Dst ip: 80.229.156.222 Type: Destination Unreachable Code: Host Unreacheable
Info May 16 15:43:18 SNTP Synchronised to server: 212.159.13.49
Info May 16 14:43:19 SNTP Synchronised to server: 212.159.6.10
Info May 16 13:43:20 SNTP Synchronised to server: 212.159.13.49
Info May 16 13:43:08 FIREWALL event (1 of 1): deleted rules
Info May 16 13:43:08 GRP Default destination is routed via gateway 80.229.156.222
Warning May 16 13:43:08 PPP link up (Internet) [80.229.156.222]
Info May 16 13:43:08 PPP CHAP Chap receive success : authentication ok
Info May 16 13:43:08 PPP CHAP Receive challenge (rhost = THN-AG2)
Info May 16 13:42:52 PPP CHAP Receive challenge (rhost = bras-red1.pr)
Info May 16 13:42:42 xDSL linestate up (ITU-T G.992.5; downstream: 5596 kbit/s, upstream: 471 kbit/s; output Power Down: 20.0 dBm, Up: 13.0 dBm; line Attenuation Down: 44.5 dB, Up: 24.5 dB; snr Margin Down: 6.0 dB, Up: 6.5 dB)
Warning May 16 13:42:35 PPP link down (Internet) [80.229.156.222]
Info May 16 13:42:17 xDSL linestate down
Info May 16 13:41:56 FIREWALL event (1 of 1): created rules
Info May 16 13:41:55 GRP Default destination is not routed anymore via gateway 80.229.156.222
Info May 16 13:41:55 xDSL linestate down
Info May 16 12:45:02 FIREWALL event (1 of 1): deleted rules
Info May 16 12:45:02 GRP Default destination is routed via gateway 80.229.156.222
Warning May 16 12:45:02 PPP link up (Internet) [80.229.156.222]
Info May 16 12:45:02 PPP CHAP Chap receive success : authentication ok
Info May 16 12:45:02 PPP CHAP Receive challenge (rhost = THN-AG2)
Info May 16 12:45:02 PPP CHAP Receive challenge (rhost = bras-red1.pr)
Info May 16 12:44:51 xDSL linestate up (ITU-T G.992.5; downstream: 5998 kbit/s, upstream: 952 kbit/s; output Power Down: 20.0 dBm, Up: 13.0 dBm; line Attenuation Down: 44.5 dB, Up: 24.0 dB; snr Margin Down: 6.0 dB, Up: 6.5 dB)
Warning May 16 12:44:45 PPP link down (Internet) [80.229.156.222]
Info May 16 12:44:26 xDSL linestate down
Info May 16 12:44:01 FIREWALL event (1 of 1): created rules
Info May 16 12:44:01 GRP Default destination is not routed anymore via gateway 80.229.156.222
Info May 16 12:44:01 xDSL linestate down
Info May 16 12:43:14 SNTP Synchronised to server: 212.159.6.9
Info May 16 12:20:55 FIREWALL event (1 of 1): deleted rules
Info May 16 12:20:54 GRP Default destination is routed via gateway 80.229.156.222
Warning May 16 12:20:55 PPP link up (Internet) [80.229.156.222]
Info May 16 12:20:55 PPP CHAP Chap receive success : authentication ok
Info May 16 12:20:54 PPP CHAP Receive challenge (rhost = THN-AG2)
Info May 16 12:20:53 PPP CHAP Receive challenge (rhost = bras-red1.pr)
Info May 16 12:20:42 xDSL linestate up (ITU-T G.992.5; downstream: 5923 kbit/s, upstream: 197 kbit/s; output Power Down: 20.0 dBm, Up: 11.0 dBm; line Attenuation Down: 44.5 dB, Up: 24.5 dB; snr Margin Down: 6.0 dB, Up: 7.5 dB)
17-05-2009 12:41 AM
Quote from: penfold Odd thing today, again a few resyncs, but as seen in the logs below, one re-sync suddenly had both up and down SNR at 6dB, and the immediate re-syncs before and after up is again at 24dB.
I think there was some misreading there, the SNR Margins in order are shown as
(Down/Up) (6.0/7.5 dB), (6.0/6.5 dB) and (6.0/6.5 dB again).
Obviously a fault somewhere, hope it is found and fixed this time rather than just lying low again.
David
18-05-2009 8:42 PM
Passed all this through to Faults, they say they can find no fault, even though all their tests show as intermittant. Sync is still as random as was, also noticed, that the router does take a hell of a long time to obtain sync, flashes like crazy for around 15secs then stops, does this another couple of times, and then gets sync, sometimes PPP session dosnt even get a chance to start before sync is lost. I attached another set of router stats, upstream now a pathetic 200odd...... Obviously something amiss, but I will jump through the hoops again. Will attach my older trusty Speedtouch 585V6, and see what happens. Can anyone suggest anything else?? I also nothiced some firewall blocks over the last couple of days, could this be Plus trying to access my router?? Also how do I use router stats, as I think I need to monitor the SNR....
May 18 19:03:40 FIREWALL event (1 of 2): deleted rules
Warning May 18 19:03:40 PPP link up (Internet) [80.229.156.222]
Info May 18 19:03:40 GRP Default destination is routed via gateway 80.229.156.222
Info May 18 19:03:41 PPP CHAP Chap receive success : authentication ok
Info May 18 19:03:40 PPP CHAP Receive challenge (rhost = THN-AG2)
Info May 18 19:03:40 PPP CHAP Receive challenge (rhost = bras-red1.pr)
Info May 18 19:03:39 xDSL linestate up (ITU-T G.992.5; downstream: 5725 kbit/s, upstream: 275 kbit/s; output Power Down: 20.0 dBm, Up: 10.0 dBm; line Attenuation Down: 44.5 dB, Up: 24.0 dB; snr Margin Down: 6.5 dB, Up: 7.5 dB)
Info May 18 19:03:13 xDSL linestate down
Info May 18 19:02:47 xDSL linestate down
Info May 18 19:02:27 xDSL linestate down
Info May 18 19:02:11 xDSL linestate up (ITU-T G.992.5; downstream: 4814 kbit/s, upstream: 90 kbit/s; output Power Down: 19.5 dBm, Up: 12.0 dBm; line Attenuation Down: 46.0 dB, Up: 26.0 dB; snr Margin Down: 6.0 dB, Up: 6.0 dB)
Info May 18 19:01:45 xDSL linestate down
Info May 18 19:01:21 xDSL linestate down
Warning May 18 19:01:13 PPP link down (Internet) [80.229.156.222]
Info May 18 19:00:55 xDSL linestate down
Info May 18 19:00:35 FIREWALL event (1 of 2): created rules
Info May 18 19:00:35 GRP Default destination is not routed anymore via gateway 80.229.156.222
Info May 18 19:00:35 xDSL linestate down
Warning May 18 18:59:45 SNTP Roundtrip exceeds limits
Error May 18 18:30:04 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 202.125.38.25 Dst ip: 80.229.156.222 Type: Destination Unreachable Code: Port Unreacheable
Info May 18 17:59:35 SNTP Synchronised again to server: 212.159.6.10
Info May 18 16:59:34 SNTP Synchronised to server: 212.159.6.10
Info May 18 15:59:34 SNTP Synchronised to server: 212.159.13.50
Info May 18 14:59:35 SNTP Synchronised to server: 212.159.6.10
Info May 18 14:56:08 GRP Default destination is routed via gateway 80.229.156.222
Warning May 18 14:56:08 PPP link up (Internet) [80.229.156.222]
Info May 18 14:56:08 PPP CHAP Chap receive success : authentication ok
Info May 18 14:56:08 PPP CHAP Receive challenge (rhost = THN-AG2)
Info May 18 14:56:08 PPP CHAP Receive challenge (rhost = bras-red1.pr)
Info May 18 14:55:12 GRP Default destination is not routed anymore via gateway 80.229.156.222
Warning May 18 14:55:12 PPP link down (Internet) [80.229.156.222]
Info May 18 14:55:11 FIREWALL event (1 of 1): deleted rules
Info May 18 14:55:11 GRP Default destination is routed via gateway 80.229.156.222
Info May 18 14:55:10 xDSL linestate up (ITU-T G.992.5; downstream: 5881 kbit/s, upstream: 491 kbit/s; output Power Down: 20.0 dBm, Up: 12.5 dBm; line Attenuation Down: 44.5 dB, Up: 24.5 dB; snr Margin Down: 6.0 dB, Up: 6.0 dB)
Info May 18 14:54:46 xDSL linestate down
Info May 18 14:54:26 FIREWALL event (1 of 1): created rules
Info May 18 14:54:26 GRP Default destination is not routed anymore via gateway 80.229.156.222
Info May 18 14:54:26 xDSL linestate down
Info May 18 14:50:52 FIREWALL event (1 of 1): deleted rules
Pick a task...
