Friday 19th March 2010Login | Register | Help
Pages: [1] 2
connecting Macs to a wireless network
« on 12/01/2009, 18:16 »
My son's home from uni (yippee  Undecided)  He has his Mac Book Pro, and can connect ok to my network, but when he's at his girlfriends, it won't connect to her dad's network. (We both use the same model Belkin router by coincidence)
He knows the WPA passkey, but it doesn't like it (I asked him to check the usual - upper or lower case etc)
If they turn off the security, then it'll connect, but obviously they don't want to do that.
Any suggestions?  Huh?
Logged
« Reply #1 on 12/01/2009, 18:27 »
Are both routers set to the same flavour of WPA ?
There are lots of different variants ( see here http://www.darknet.org.uk...reless-security-acronyms/ )
Maybe one is set to WPA2 or maybe AES instead of TKIP ?
Hope that helps
Logged
« Reply #2 on 12/01/2009, 18:32 »
He says WPA with passkey (I'm pretty sure that the router won't handle WPA2) and it works ok on my router, so I don't think he's using the wrong one on the Mac, but I'll check to be sure.
Logged
  • adiewoo
  • Forum Moderator
  • View Profile
« Reply #3 on 12/01/2009, 19:40 »
Normally gives some kind of error if it won't connect, is it saying anything?
Other thing is does the other router have MAC filtering on?
Forum Moderator and customer - plusnet Unlimited - March '09 plusnet Premier Option 1 - August '03 - March '09
PUG IRC - http://usertools.plus.net/irc/ - usertools.plus.net:6667, Channel #Usertools.
Logged
« Reply #4 on 12/01/2009, 20:22 »
MAC filtering was off (he checked) and I think the error message was something like password incorrect.
Logged
  • adiewoo
  • Forum Moderator
  • View Profile
« Reply #5 on 12/01/2009, 20:39 »
Not got a hidden SSID?
Logged
« Reply #6 on 12/01/2009, 22:50 »
The SSID was visible, and the Mac tried to connect, but the message just said that the password wasn't accepted.
Logged
  • Jameseh
  • Plusnet Staff
  • Napier for England!
  • View Profile
« Reply #7 on 13/01/2009, 10:22 »
Have they tried changing the password?
I know it sounds silly...
James Bailey
Plusnet New Recruits and Advisor Graduation Lead
Service Status || RSS
Logged
  • tgr
  • View Profile
« Reply #8 on 17/03/2009, 10:43 »
I run a mac on a network and the router is WPA2 so that maybe the problem
Best Wishes
Gordon
Logged
« Reply #9 on 30/03/2009, 22:37 »
What version of OS X is the Macbook Pro running? Early versions of Leopard (10.5) had issues with connecting via Airport to certain wireless networks, but Apple seems to have fixed this since 10.5.3 or later. The latest version is currently 10.5.6, if running Leopard, I'd suggest downloading and installing the 10.5.6 Combo Updater - see here - the Combo version can fix things that the incremental updates occasionally break (or miss). If it's running Tiger (10.4) then this probably won't not be relevant.
Sometimes you need to insert a $ before the password on a Mac with certain routers. It could be worth trying that.
Finally, check the router's firmware is up-to-date.
MacOS10
ʎɐqǝ uo pɹɐoqʎǝʞ ɐ ʎnq ı ǝɯıʇ ʇsɐן ǝɥʇ sı sıɥʇ
_______________________________________
Logged
  • TomP
  • Merlin HC3
  • View Profile
« Reply #10 on 06/10/2009, 18:38 »
Having the same issues now.  Woke up one morning and the router has decided to bump the macbook off. No error message, but it just doesn't connect to the Voyager 2110.  iPhone comes up with a different error saying the password has been rejected.  Know its correct, tried changing a few times, upgrading hardware etc.
Running Snow Leopard
Logged
  • Jameseh
  • Plusnet Staff
  • View Profile
« Reply #11 on 07/10/2009, 10:44 »
It might be a stupid question, but have you tried rebooting the router?
James Bailey
Logged
  • TomP
  • Merlin HC3
  • View Profile
« Reply #12 on 07/10/2009, 21:42 »
As in a normal on/off or a reboot via the config manager?
Logged
  • TomP
  • Merlin HC3
  • View Profile
« Reply #13 on 07/10/2009, 22:02 »
Tried a reboot via the config manager.  Seems like I can connect....
As I typed that I got a lost connection symbol on my airport, can only get a connection via the ethernet cable.  iPhone seems to hold the connection until I go upstairs and it drops.  Used to be able to get a connection in the upstairs bedroom no probs.  No changes in the modems position, electrical items around it or anything.  Very frustrating.  Last time a firmware upgrade solved this problem.  Router is fully up to date.
Logged
  • TomP
  • Merlin HC3
  • View Profile
« Reply #14 on 07/10/2009, 22:11 »
Right, iPhone seems to work (Not checked range yet) Macbook can't connect.  Whenever I go into network diagnostics its telling me its connecting to the modem but cannot get the network settings.  Can take a screenshot it needs be.  The security is correct, so is the password.  No idea what to do next.
Logged
« Reply #15 on 09/10/2009, 15:00 »
Tom, your silence suggests that you may have solved your problem.
However the last time I had a similar 'insoluble' problem I solved it by a, updating the modem/router software - it seemed an improbable reason as the router/modem had worked flawlessly for the previous years and b, changing wifi channel - it would seem that all my neighbours and their friends had got wifi and for no good reason this appeared to have an effect on the connection. Neither of these actions made any sense but it solved the problem which hasn't reappeared yet.
Logged
Pages: [1] 2
Jump to:
Related Sites
Community Apps
About Plusnet
Powered by SMF | SMF © 2006-2008, Simple Machines LLC
Add to Technorati Favourites
