AVG
- AVG
AVG
17-08-2008 12:34 AM
Re: AVG
17-08-2008 12:42 AM
Re: AVG
17-08-2008 1:01 AM
Re: AVG
17-08-2008 1:26 AM
I only use AVG Internet Sercurity on my main machine but will dig out the file.
Re: AVG
17-08-2008 1:32 AM
Re: AVG
17-08-2008 1:47 AM
Re: AVG
17-08-2008 1:51 AM
Re: AVG
17-08-2008 1:53 AM
Re: AVG
17-08-2008 9:22 AM
1 - Start up AVG,click Update Now.
2 - The list of updates is shown in Popup, click on the more information link.A list of updates will be shown.
3 - Click on and save all updates in a file except the last one - http://downloadfree.avg.com/update/u7iavi1616oo.bin - because this is causing the problem.
4 - Cancel the update and instead click on Tools > Update from Directory and go to the file where you saved the updates.Install these and AVG should be working properly again.
http://www.neoseeker.com/forums/62/t1216894-avg-free-8-bin-file-missing/
Hope this helps
Rob
Re: AVG
17-08-2008 9:25 AM
Re: AVG
17-08-2008 9:39 AM
From AVG Forum
Currently the update for AVG Free v8 is corrupted... you will have to wait for AVG Technologies to address the issue with the update.
Reporting the issue again by other users here will not do any good util it is resolved.
The updates that your AVG currently have will still provide the protection it is setup to detect. In otherwords, not being able to get this update will not make your AVG Free ineffective and as soon as AVG Tech resolves the issue you will be able to update to the current virus definitions at that time.
So in short... please do not post to report the issue, its already known. Also please be patient until AVG Technologies can address the issue.
Re: AVG
17-08-2008 10:23 AM
Quote from: coastergrotto It just says a bin file is missing when you go to Update.
I've just noticed this problem as well, although it says update failed it still shows todays date for the latest update.
Also running V8.0.138
Paul
Edit: sorry didn't read the post by artmo, must learn to read the whole thread before posting
Re: AVG
17-08-2008 10:50 AM
Thanks for that, although it does solve the problem whilst the computer is up and running if you reboot the problem reoccurs until you go through the same procedure again. I don't wish to switch off Automatic Updates, so I have altered the Zone Alarm Firewall program to 'Ask' when installing AVG updates so I hope by denying it access in the menatime it will solve the problem. Rebooting now.
Re: AVG
17-08-2008 10:57 AM
Re: AVG
17-08-2008 11:01 AM
Now back to the Olympics.
