Saturday 20th March 2010Login | Register | Help
Pages: [1]
"Outbound Proxy" setting
« on 16/03/2008, 23:18 »
I note that some users report successful set-ups not using an outbound proxy setting. On the Gradwell support portal I found the following under the heading Standard settings for most SIP Phones/devices:"There will be no need to use the outbound proxy if your adaptor/phone has a static public IP address assigned to it."
Does this apply when one is using the VoIP trial service "sip2.plus.net" hosted by Gradwell if one is using a Plusnet account with a static IP address? In which case would the reliability of the service be improved if the outbound proxy setting was also "sip2.plus.net"?
Logged
« Reply #1 on 16/03/2008, 23:55 »
This message applies to almost all SIP services and means if the device you are using has a public IP assigned to it directly.
For the majority of our customers, regardless of having a Static or Dynamic IP, this will not be the case. This situation requires that you have a block of IPs or have a router that will transparently push the data into your internal network (The X-Modem is the only one I know that does this).
One exception to this is customers that have a modem/router with a built in SIP client, such as the Draytek Vigor 2600.
Phil Richardson
PlusNet Business Support Analyst
Logged
Pages: [1]
Jump to:
Related Sites
Community Apps
About Plusnet
Powered by SMF | SMF © 2006-2008, Simple Machines LLC
Add to Technorati Favourites
