Sunday 8th November 2009Login | Register | Help
Pages: [1]
Successful transfer-in for DNS Domain Hosting Only
  • jws
  • View Profile
« on 13/03/2006, 22:44 »
Having checked and read forum posts on this subject before taking the plunge of setting up Domain Hosting Only Without Registration, I thought I would publicise my complete and straightforward success, to encourage others -- since normally people only post problems and difficulties, so successes go silent and unremarked.
I retained the Domain Registration with my existing company, Easily: http://easily.co.uk.  PlusNet are hosting the DNS, webspace and e-mails.
At 09:15 this morning I changed the DNS servers for my .org.uk domain to point to PlusNet's DNS servers using the Domain Management facility of my Registration agent / TAG Holder Easily.  The changes were actioned immediately, verified by checking my Nominet Registration entry using WHOIS.
At 09:30 I raised a Manual Domain Hosting ticket with PlusNet using the Contact Us Wizard for Manual/DNS-Only Hosting.
These are the words I used in the text box of the wizard:
This is a Domain Hosting Only request for:
thechurchinbinleywoods.org.uk
I wish the existing TAG holder to remain as such, and require "Domain Hosting Only" from PlusNet. Please DO NOT transfer the TAG.
The name server addresses of the domain are pointing at the FORCE9 DNS servers, as verified by WHOIS.
As per your instructions, I hereby raise a Contact Us query requesting that you enable the above domain on your DNS servers, and my webspace and my e-mail account.
At 11:26 PlusNet actioned the ticket.
From that time the domain was available to administer in the PlusNet Domains Panel.  This enabled me to specify the subdirectory under /htdocs where I wanted the Domain to point.
Two hours later the DNS for www.thechurchinbinleywoods.org.uk was live and pointing at my webspace, and e-mails were being routed to my PlusNet e-mail account.
However, the domain was still pointing at the root of my webspace and not at the subdirectory I had set (which was a pity, really).  Another 2 hours later the Domains Panel setting took effect, and the transfer was complete - 6 hours from start to finish, and as smooth as it could have been.
_________________________________________
I do have some comments:
(1) The "Help" and Information is unclear and muddled.  The route through to the actual Wizard for Hosting-Only-Without-Registration is tortuous and counter-intuitive.  You have to travel along the Hosting-With-Registration path a fair way before the escape route to Without-Registration is provided.
(2) I wanted to re-write "native" URLs so that the proper Domain name always shows in the browser.  I also discovered that domain.org.uk points at my webspace as well as www.domain.org.uk.  I wanted to rewrite the "bare" domain URL so that the "www" is always present.
This is my .htaccess file, in the /htdocs directory:
# Re-write native (js2js) cibw and CiBW address with the cibw domain name:
RewriteCond %{HTTP_HOST} ^www\.js2js\.plus\.com [NC]
RewriteRule ^cibw/(.*) http://www.thechurchinbinleywoods.org.uk/$1 [NC,R=permanent]
# Put the www in front of bare churchinbinleywoods:
RewriteCond %{HTTP_HOST}   ^thechurchinbinleywoods\.org\.uk [NC]
RewriteBase /cibw
RewriteRule /(.*)         http://www.thechurchinbinleywoods.org.uk$1 [R=permanent]
There was a certain amount of trial and error in the second part determining the RewriteBase, and the omission of a / in the RewriteRule between the .uk and the $1.
(3) I'd already made the other bit of necessary preparation in the website itself.  Before the change, while it was still using the "native" URL, the root directory of the website was /cibw/.  So any links that I wanted to be absolute rather than relative to the page started with /cibw/....   But with the new Domain, the root directory of the website is just / .  I used some JavaScript in the <head> of each page to set the root directory dependent on the URL used to display the web page:
if (location.host.toLowerCase() == "www.thechurchinbinleywoods.org.uk") {
var siteroot = "";
else {
var siteroot = "/cibw";
//Open a link that is fully-qualified relative to the site root:
function rlink(link) {
  window.location = siteroot + link
And then every absolute link has to be made either using the function rlink() or by using document.write within JavaScript to write a link using the siteroot variable.  rlink() is easier to code, but document.write is more user-friendly.  In fact I only use non-relative links for the static navigation that has to work from every page regardless of how deep it is in the structure.
Logged
« Reply #1 on 14/03/2006, 18:53 »
Thanks, as you say it's rare to see a 'solution' posted outright. I'm sure this will help others in the future, I'll make a note to point folks with a similar problem here.
Indeed, this may be useful for myself in the not too distant future, I may be looking to host a 'new' website on Plusnet, depending on the outcome of a project I'm working on. This will require a domain of it's own. Your solution is one way to tackle the problem.
Nice 'unfussy' website too Smiley
Chicken
Logged
« Reply #2 on 17/03/2006, 08:35 »
Can you tell me if my name servers should be:
ns33.1and1.co.uk
ns34.1and1.co.uk
when I am hosting my website www.bagpuizewi.co.uk at plusnet and domains names are from1and1.
If not how do I change them at 1and1 without an error message?
Logged
« Reply #3 on 17/03/2006, 09:08 »
Hello, I have now solved my problem regarding the ns numbers. Phoned 1and1!!
Thanks.
Logged
  • boothnet
  • Guest
« Reply #4 on 17/03/2006, 20:29 »
Hi shottle
What was the answer
Logged
« Reply #5 on 18/03/2006, 08:30 »
ns33.1and1.co.uk
ns34.1and1.co.uk
Hi Steve, well as my DNS were showing thus above, I knew these were not correct and so checked out at DNS STuff     http://www.dnsstuff.com/
the churchinbinley website
Yes OK his was not showing that, but force9.net and I knew that mine HAD been correct so I rang 1and1 and they said, all you need to do is to alter the DNS at 1and1 and make sure you have 'Mydomain' [ I think it is called that - it is the other option to 1and1domain] showing and then enter the DNS numbers given to me by PN. These were:-
ns1.force9.net 195.166.128.16 and ns2.force9.net 195.166.17
There is no necessity to put in anything else bar ns1.force9.net  and ns2.force9.net
I changed them over and then emailed PN with a like message as we were shown by the webmaster of  churchatbinley website, which I had altered.
Nothing for 8 hours and now I have www.bagpuizewi.co.uk simply showing my parents directory and two directories.  I have to  adjust this yet - hopefully.
At present, I can view the source code, which seems hopeful  though  I do not know exactly what will happen when I introduce an HTML file to stop the directories in my webspace being seen.
You now have to enter www.bagpuizewi/.co.uk/bagpuizewi - BUT you are able to also go to another page on the site and if you refresh you stay on the page too and not get the index page again!!!
So far, this has taken me three months to understand!! But then I am but an elderly, simple amateur webmaster who is self taught.
Logged
« Reply #6 on 18/03/2006, 12:54 »
This rather looks as if I now understand it all - correction - I still don't!!
Logged
  • boothnet
  • Guest
« Reply #7 on 18/03/2006, 20:38 »
Hi shottle you've come a long way.
I'm learning all the time.  To me its part of the fun/challenge.  Worthwhile when you work things out
Logged
« Reply #8 on 19/03/2006, 17:51 »
At Last! I now have two domain names and I can see my source code.
All you seemingly need to do is to change your domain pointing - check with DNS Stuff - and then raise a ticket.
I have no moonphase nor any other file uploaded - simply my websites.
It can be done!!  ----- Phew! three months of working on it and ringing Plusnet -- raising a ticket seems to be the answer.
www.gravematters.org.uk
Logged
« Reply #9 on 19/03/2006, 17:53 »
What Steve...you should see how much older I am though! <grins>
Logged
Pages: [1]
Jump to:
Related Sites
Community Apps
About Plusnet
Powered by SMF | SMF © 2006-2008, Simple Machines LLC
Add to Technorati Favourites
