Saturday 20th March 2010Login | Register | Help
Pages: [1]
ccgi server case sensitive
  • funkin
  • Guest
« on 13/03/2006, 14:02 »
I just uploaded my website and tested it only to find that the server is case sensitive.
Why is this, i have never had this issue before (apart from within flash or js, but thats differernt)
Logged
  • Peter Vaughan
  • Usergroup Member
  • Unofficial ledgendary bright spark bod!
  • View Profile
« Reply #1 on 13/03/2006, 14:07 »
PlusNet use UNIX based web servers which is case sensitive, unlike a MS based server which is not.
Just make sure you use all lower case for any filenames and files and it will work on both types of server.
I can only assume you have always used windows based servers in the past.
plusnet ADSL Customer (PlusNet Pro)
PlusNet Usergroup | PUG Forums | Usertools | PUG Issue Tracker - Please vote!!
Volunteer at the National Museum of Computing @ Bletchley Park - Looking for donations of old games consoles, PCs and software. Contact me for details
Logged
  • funkin
  • Guest
« Reply #2 on 13/03/2006, 14:08 »
Thanks for your reply. I have resolved this issue now with a quick bit of remaming.
Logged
Pages: [1]
Jump to:
Related Sites
Community Apps
About Plusnet
Powered by SMF | SMF © 2006-2008, Simple Machines LLC
Add to Technorati Favourites
