Fingering autoturn
- Fingering autoturn
Fingering autoturn
16-10-2007 9:49 AM
I had a recurring problem with dequeueing mail from the autoturn server.
Initially, I had a cron job which periodically issued:
"finger postmaster@autoturn.plus.net"
Now, most of the time, this worked absolutely fine. However, sometimes the command simply seems to hang indefinitely.
Every morning, I had to run a 'killall -9 finger' to get rid of the excess processes, which isn't very elegant.
So, I decided to expand my simplistic mail dequeueing command with a bash script to do the same, except it will now wait for a specified amount of time, then kill the finger process if it's still hanging around.
For anyone else having similar problems dequeueing mail using autoturn, here is the script. Feel free to use as you require.
Hope it's of some use to someone.
B.
#!/bin/bash
# Author: Barry Zubel
# You are free to use this script any way you wish.
TIMEOUT=60
FINGER=/usr/bin/finger
DEST=postmaster@autoturn.plus.net
# Run the finger command.
$FINGER $DEST &
# grab the PID of the finger command
pid=$!
# sleep for a specified amount of time
sleep $TIMEOUT
# kill the finger command, if it's still running. Redirect all output
# to /dev/null
kill -s SIGTERM $pid > /dev/null 2>&1
B.
Message 1 of 2
(1,399 Views)
1 REPLY 1
Re: Fingering autoturn
16-10-2007 9:56 AM
neat little script
Message 2 of 2
(307 Views)
