For the last few hours I've had 2mb dl speed and 100 extra ping to all servers
- For the last few hours I've had 2mb dl speed and 1...
29-12-2015 10:09 PM
I have reconnected several times and it doesn't change. What is going on?
Re: For the last few hours I've had 2mb dl speed and 100 extra ping to all servers
29-12-2015 10:25 PM
29-12-2015 10:30 PM
29-12-2015 10:32 PM
http://www.speedtest.net/result/4954352220.png
And i keep getting drop outs from teamspeak 3 constantly.
<22:13:12> "Sadiro" dropped (connection lost)
<22:14:40> "Sadiro" connected to channel "Room 1"
<22:36:17> "Sadiro" dropped (connection lost)
<22:38:41> "Sadiro" connected to channel "Room 1"
<22:52:21> "Sadiro" dropped (connection lost)
<22:53:21> "Sadiro" connected to channel "Room 1"
<23:15:34> "Sadiro" dropped (connection lost)
<23:15:37> "Sadiro" connected to channel "Room 1"
<23:19:42> "Sadiro" dropped (connection lost)
<23:19:53> "Sadiro" connected to channel "Room 1"
Congestion at its best?
29-12-2015 10:40 PM
29-12-2015 10:55 PM
more like 140 extra ping, though. averaging 150-170 ms ping atm.. normal is 15-25 ms.
i suppose it might be some sort of temporary measure due to rerouting around outages caused by the weather, more people on the infrastructure = reduce available speeds so that everyone gets something, in order to get people back online.
29-12-2015 11:00 PM
3Mb FTTC
29-12-2015 11:22 PM
http://www.speedtest.net/result/4954444601.png
UPDATE:
23:49
http://www.speedtest.net/my-result/4954489625
Things getting back to normal now.
29-12-2015 11:36 PM
dropped from 28-30mb to a 5-6mb and ping inscreaed by 100-200 poor show!
30-12-2015 12:11 AM
I think it's only getting slightly better as demand is dropping, people going to bed etc. I think the problem is still there. I am still getting less than 20mb d/l which is way less than normal. We will see how it is in the morning.
30-12-2015 12:51 AM
http://www.speedtest.net/result/4954585762.png
30-12-2015 1:00 AM
30-12-2015 9:01 AM
It is normally the second to last line of the output array and contains the name of the gateway too as part of the readable name. This is the IP address of the physical machine you connect through. Would be nice to see if there are all the same.
30-12-2015 9:41 AM
[5] => 11 link-b-central10.pcl-ag08.plus.net (212.159.2.191) 4.274 ms
You are currently connected to gateway pcl-ag08.
This is located in City Lifeline House.
3Mb FTTC
30-12-2015 9:48 AM
3Mb FTTC
