windows 10
- windows 10
windows 10
18-10-2015 9:41 PM
Since 'upgrading' from Window 8 to Windows 10, using Outlook 2013, my outgoing mail gets stuck in the outbox. I've checked my settings & everything appears correct. After I check the settings a trial email is sent correctly, but whatever's in the outbox won't send. Any ideas?
Message 1 of 4
(1,350 Views)
3 REPLIES 3
Re: windows 10
18-10-2015 10:12 PM
You need to follow this procedure http://answers.microsoft.com/en-us/windows/forum/windows_10-win_upgrade/outlook-issues-following-upg...
Worked for me in exactly the same situation.
Message 2 of 4
(807 Views)
Re: windows 10
18-10-2015 10:23 PM
Yep, I've had to do that for clients with Outlook sending issues on W10. Worked a treat.
(sfc /scannow run as administrator for those who can't follow the link)
Message 3 of 4
(807 Views)
Re: windows 10
22-10-2015 8:54 PM
Great!! worked first time. It took hours to do the scan, I left it running all night. It certainly fixed the problem. Thanks for the help.
Message 4 of 4
(807 Views)
