Ip Profile
- Ip Profile
Ip Profile
30-06-2015 12:47 PM
thanks
Re: Ip Profile
30-06-2015 2:13 PM
Re: Ip Profile
30-06-2015 2:20 PM
Thanks for your quick response
Re: Ip Profile
30-06-2015 3:29 PM
Re: Ip Profile
30-06-2015 3:31 PM
thanks
Re: Ip Profile
30-06-2015 8:16 PM
This will refresh the operational profile on the line without dropping synch which could cause problems.
Re: Ip Profile
01-07-2015 10:01 AM
I have not rebooted the router just got a new ip address.The spped is still the same as yesterday.
My ip profile is still 3 mp and my speed is about 2.75 mp.
However my sync has improved it is now 5088. Had a few disconnections during the night but has been fine for nearly 9 hours now.
Max. DSLAM throughput kBit/s 5184 448
Min. DSLAM throughput kBit/s 4896 352
Attainable throughput kBit/s 6056 864
Current throughput kBit/s 5088 448
Latency 4 ms 4 ms
Bit swap off on
Signal-to-noise ratio dB 8 13
Line attenuation dB 52 32
Power cutback dB 0 0
Loss of
Signal Loss of
Frame Forward Error Correction Cyclic Redun-
dancy Check No Cell Delineation Header Error Control
CPE 0 0 318018152 3843 0 0
COE 408 680 204 12 1 136
Re: Ip Profile
01-07-2015 1:22 PM
Re: Ip Profile
06-07-2015 11:02 AM
Just a quick update my ip is now 4.5 mp and my speed is about 4.16 which is brilliant!! I am connected at 5376
I keep getting a couple of disconnections all at night which used to happen in the past but the good news my ip is not changing!!
so what ever you did thank you!! Lets hope it keep up.
I find Plusnet very good at customer care so thank you.
