Connection problems with WIFI on New Fibre Router
- Connection problems with WIFI on New Fibre Route...
17-06-2015 2:12 PM
We just seem to get "Authorization problem" on the devices .
The only way to resolve is to power cycle the modem , often take a couple of goes to get the WiFi back .
Reported this to PNet . who told me to try various Channels, did this to no improvement
Recently been sent another modem, and all OK for about 6 days then exactly the same?.
power on and off gets the WiFi back on .
Any clues peeps , a real pain to have to keep do this ..
the modem does get quite warm after a few days use, and the range on the WiFi is pretty poor all the time. no where near as good as the previous BB routers..
As a aside ...when we first got both routers we found the browsing response almost instant , but after a few days use this response seems to slow down,
EG any web page hangs for a few seconds showing " connecting" then appears in a blink , before it was instantaneous?
this has happened now on the 2nd Router ?. weird ! .
Ta
Chris
Re: Connection problems with WIFI on New Fibre Router
18-06-2015 12:06 PM
18-06-2015 2:32 PM
It does seem strange that you are having to reboot the router to get the wireless signal again,
I've passed a message onto our products team who will see if they have any suggestions to what it could be.
19-06-2015 3:17 PM
Nothing wrong in the router side .. just the WiFi ? stops working , ( the light stays on) ..
to try to help the range problem I have put the router up high on a Shelf now , and with a large square of Foil behind it to try and act as a reflector./
but with little effect ..
Sky on demand and our android TV box work well when its working , but then they have line of Sight!! , everywhere else it very hit & miss in the range dept . .
well until it shuts off !!
Chris
19-06-2015 4:11 PM
The more examples of this the better as that will help us get to the bottom of the issue. Hopefully we should have an update soon and once we do we will be in touch
20-06-2015 12:20 PM
24-06-2015 6:39 PM
C.
24-06-2015 7:44 PM
24-06-2015 9:25 PM
24-06-2015 10:33 PM
And for the 2 android tv boxes and the WIi and the Xbox
C.
29-06-2015 2:52 PM
Not a lot on Suggestions Front ..
Chris
Quote from: Wrighty11 Hey up,
29-06-2015 7:49 PM
In the way of suggestions it would seem only a firmware update or a different device will resolve surely?
02-07-2015 11:37 PM
Quote from: Strat I started with WiFi, went to home-plugs and ended up running cat5e around.
You should have just bought a decent vdsl/router although home plugs do work really well especially in newer houses.
05-07-2015 9:47 PM
I think the sagecom router is a bit pap.
07-07-2015 7:55 AM
This lil Router has now developed the Need to Randomly crash and reboot for no apparent reason ,
this tends to Sod up any downloading of files and especially when watching streaming video or on demand stuff .
C.
