Delay in rectifying phone fault
- Home Phone
- Delay in rectifying phone fault
27-02-2015 12:04 PM
Re: Delay in rectifying phone fault
27-02-2015 12:25 PM
Sorry about the delay here, I'm just taking a look now.
I'm retesting the line due to the gap of a few days, I should have the results shortly and I'll update you via the ticket on your account asap.
27-02-2015 12:31 PM
28-02-2015 9:12 AM
28-02-2015 9:19 AM
To be is to do - Kant
do be do be do - Sinatra
28-02-2015 2:00 PM
02-03-2015 9:59 PM
Hope you can help/check my line thanks
Richard
03-03-2015 4:03 PM
03-03-2015 6:11 PM
03-03-2015 6:24 PM
Good to know it's been fixed. Let me have a look at a goodwill gesture for the downtime.
@englishrick
I'll pick up your ticket shortly.
@mash
I see your ticket has been picked up and the fault reported through.
03-03-2015 6:30 PM
I'm a bit limited on when I can book based on the times provided in the ticket. I've booked what I think is the best available appointment for you, I'll confirm on the ticket.
03-03-2015 6:51 PM
03-03-2015 6:56 PM
03-03-2015 9:48 PM
Quote from: englishrick Heres a recording of my Crackle problem from this afternoon.. https://www.dropbox.com/s/fle5p6i55vlippx/Phone%20Crackle.m4a?dl=0
That isn't good! Do you get the same if you plug a corded phone direct in to the test socket inside the master socket without a filter (or router)? You need to eliminate it being a bad connection internally.
BTW: To check a line for noise dial 17070 and pick option 2 as that gives an open line with no messages - makes it easier to hear the noise.
04-03-2015 8:16 AM
dick:quote
- Home Phone
