Loading indicator never goes away.
- Feedback
- Community Site Feedback
- Loading indicator never goes away.
06-02-2015 8:57 AM
I went in to edit this earlier and I clicked on the page / pencil icon to edit. Having made the change I clicked the save button and window with an animated 'busy' icon and the text 'Loading...' popped up, and never goes away. Using a new tab I can see the update has in fact been made so there appears to be a hiccup with the code.
Also, on a site related note FF Web Developer Tools shows this:
error for default.css line 451, among others for the css files used in this page 'Start new topic'
Quote Expected 'important' but found 'johnny'. Expected ';' or '}' to terminate declaration but found 'johnny'. Declaration dropped.
7 REPLIES 7
Re: Loading indicator never goes away.
06-02-2015 10:03 AM
This has always been the case - only on the quick edit - I have no idea why but a page refresh does fix it
However I have always seen that the change has happened even though the busy icon is still there
06-02-2015 10:08 AM
Thanks Oldjim I did suspect it had history as I assumed I wasn't the first to notice.
16-02-2015 7:23 PM
A bit late to the party on this. Isn't this just one of the issues from http://community.plus.net/forum/index.php/topic,128159.0.html ?
I still get that periodically, but I'm not sure what a "quick edit" is?
Have I missed something
I thought there was only one "edit" - the Modify button?
I can also get it some times on a normal post
Quote from: Oldjim This has always been the case - only on the quick edit
16-02-2015 7:32 PM
I just refresh the page
To do is to be - Neitzsche
To be is to do - Kant
do be do be do - Sinatra
16-02-2015 7:59 PM
Well that's one of the standard workarounds, but can occasionally result in a double post
16-02-2015 9:33 PM
@anotherone
16-02-2015 10:17 PM
I can get the issue even using the "Modify" button.
