Something wrong
- Something wrong
Something wrong
29-12-2014 10:47 PM
But looking at the router logs I keep seeing "SNTP Unable to contact server: 212.159.13.50" and ".... 212.159.13.49"
The first is the Plusnet timeserver, ntp.plus.net and as my router is stuck permanently on "Date: 01-01-2000" with no current time update, something is wrong somewhere. Are the PlusNet timeservers down?
Re: Something wrong
30-12-2014 10:47 AM
Re: Something wrong
30-12-2014 10:55 AM
This is usually caused by having the PlusNET firewall (see connection settings in the user portal) set to high.
Re: Something wrong
30-12-2014 11:20 AM
My router has always got the correct time shortly after booting, the firewall is set to the default 'Medium Security'. Now the SNTP request fails every time, even when carried out manually from the 'Device Access Scheduler' menu.
My Noise Margin is all over the place following reboots, it is normally a steady 6dB but it now can be in the range from 12 - 1 dB. It is currently about 10dB, which accounts for somewhat slower than normal speed.
Any ideas?
Re: Something wrong
30-12-2014 11:30 AM
As for the rest of your question, please gather and post the information requested under the speed issues thread.
Re: Something wrong
30-12-2014 11:36 AM
Quote My access to the Internet seems subjectively slower today and my broadband speed is now down a couple of Mbps after a loss of connection earlier.
What speeds do you normally see and what are you getting at the moment?
Re: Something wrong
30-12-2014 11:38 AM
'Standard
Firewall Settings
This level is protected and not editable.'
I have NEVER seen this before. I need to know what is going on. I will be closing down now and try to be in contact later.
Re: Something wrong
30-12-2014 11:44 AM
Re: Something wrong
30-12-2014 6:06 PM
I must say, I still find the Technicolor TG582n router 'Task Oriented' web interface confusing...
SNTP still fails on boot up, router clock still stuck on 1 Jan 2000.
DSL Connection
Link Information
Uptime: 0 days, 0:16:04
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 1,208 / 14,335
Data Transferred (Sent/Received) [kB/MB]: 393.18 / 1.71
Output Power (Up/Down) [dBm]: 12.6 / 0.0
Line Attenuation (Up/Down) [dB]: 14.3 / 28.0
SN Margin (Up/Down) [dB]: 6.7 / 9.4
My normal download speed is 16 - 17Mbps and Noise Margin 6dB, so the current 9.4dB presumably accounts for the somewhat lower speed.
Re: Something wrong
30-12-2014 6:15 PM
Re: Something wrong
30-12-2014 6:28 PM
I recently upped the PlusNet Firewall (Not Router) from 'Low' to 'High'. Everything seemed to work OK so I left it as it was and forgot about it. This failure of SNTP requests seems now to have been a consequence of that. I just reduced the PlusNet Firewall back to 'Low' and on rebooting my router is now updating the clock.
Does anyone know if there is a higher setting for this than 'Low' that will allow SNTP messages through?
TIA
Re: Something wrong
04-01-2015 12:28 AM
As I reported previously, my broadband speed has dropped a bit both on upload and download. This seems to be caused by the noise margin going from the long term normal 6dB level to around +9dB. This happened between 23 December and 24 December:
Tue 23 Dec 2014 12:39:34, Noise Margin (dB)= 5.9, Connection Speed (Kbps)= 17017, Upstream NM= 6.2, Upstream Sync= 1211
Wed 24 Dec 2014 14:41:01, Noise Margin (dB)= 10.0, Connection Speed (Kbps)= 14702, Upstream NM= 11.8, Upstream Sync= 680
Noise margin and speeds have stayed at these levels ever since. I do sometimes have slight crackling noises on my phone line. Not on a BT Quiet Line test, but on incoming calls (don't usually use landline for outgoing calls) and also I sometimes get distorted, crackling speech on incoming calls. Most often from somebody who has a mobile that puts out a high level audio signal.
Re: Something wrong
04-01-2015 12:48 PM
Who do you pay your phone bill to?
Re: Something wrong
04-01-2015 1:37 PM
Re: Something wrong
04-01-2015 1:51 PM
A marginal broadband issue with a possible copper problem with separate suppliers is a very bad place to be.
You need to have PlusNet conduct full copper tests - both voice and BB tests. These can deliver different answers - it is not unknown for voice copper tests to report "OK" and ADSL copper tests to report "fail" - given that ANY copper issue ought to be addressed to the phone providers (CP) rather than the ISP, having a separate CP to the ISP can be very problematic.
Hope fully CRT will pick this up on Monday - they might require you to raise a fault report here - http://faults.plus.net - there is no harm in you just getting on and doing it now.
