Windows 8.1 update : help needed.
- Windows 8.1 update : help needed.
19-11-2014 5:03 PM
When I try to access the appropriate Items in the control panel to adjust the power switching etc. or go to the windows update pages to try to delete KB3000850 the control panel freezes.
I tried System Restore but it stayed on" System restore is initialising" for nearly half an hour until I shut down.
I'm VERY relucant to reinstall as I assume I would have to go through updating from 8 to 8.1 all over again and would rather just bang my head against a brick wall.
Can anyone offer any better suggestions please?
Re: Windows 8.1 update : help needed.
19-11-2014 5:20 PM
Quite a few people are saying it interacts badly with Avast!, so maybe if you are running that it is worth changing to something different for a bit (if performance will let you).
I just installed the update (despite the risks) and it seems to have gone smoothly for me. I had been an Avast! user, but changed to Windows Defender after some Avast! javascript performance issues.
Somewhat after the horse has bolted for you I am afraid, but I use EaseUS Backup Free for regular backup. (I used to use Acronis for the same purpose, but that started behaving very badly at one point so I gave up on it.)
They both mean you can recover a complete installation from the backup point. Much more space consuming than System Restore; but work when the system is somewhat broken (like yours) or even if it gets completely broken.
19-11-2014 6:01 PM
19-11-2014 6:10 PM
I have been using Aomei backupper for a while but I'm not sure I know how to restore from it (correction. I'm damn sure I don't know that but maybe I might know someone who does - at a very moderate price.)
19-11-2014 6:55 PM
19-11-2014 8:20 PM
I may well reinstall it some time, it does have better rating than most for detection.
Good luck with getting machine running properly again, problems like that are such a wasteful hassle.
19-11-2014 8:49 PM
19-11-2014 8:54 PM
Choose 'Troubleshoot'.
Choose 'Advanced Options', then 'System Restore'.
System Restore is far more likely to work if you start it this way.
19-11-2014 11:38 PM
20-11-2014 9:24 AM
As I am fairly conservative with my web browsing and other computer use I shall probably stick with Windows Defender for the forseeable future.
For now, my thanks to everyone concerned for their help and advice.
20-11-2014 9:58 AM
20-11-2014 10:17 AM
I've just finished reading through the Avast forum and loads of people seem to have the same problem. Try this link.
https://forum.avast.com/index.php?topic=160717.0
20-11-2014 10:43 AM
Have been quite happy with Avast but have now to decide whether it goes.
20-11-2014 10:48 AM
20-11-2014 10:50 AM
