Why Files amended on CCGI: WiredMinds eMetrics tracking with Enterprise Edition?
- Everything else
- Why Files amended on CCGI: WiredMinds eMetrics tra...
19-07-2014 10:42 PM
<!-- WiredMinds eMetrics tracking with Enterprise Edition V5.4 START -->
<script type='text/javascript' src='https://count.carrierzone.com/app/count_server/count.js'></script>
<script type='text/javascript'><!--
wm_custnum='de...ad';
wm_page_name='index.html';
wm_group_name='/services/webpages/c/c/ccgi.jxxxxb.com/public';
wm_campaign_key='campaign_id';
wm_track_alt='';
wiredminds.count();
</script>
<!-- WiredMinds eMetrics tracking with Enterprise Edition V5.4 END -->
A quick Google and it would appear that Hostopia are messing about with peple's files, not just at PlusNet. Anyone know what this is, why its there, how I benefit and, if I want to, how to stop it ?
I presume it's to do with the web analytics mentined on the FAQ. But the FAQ does not mention that files are modified to add Javascript.
Thanks.
Re: Why Files amended on CCGI: WiredMinds eMetrics tracking with Enterprise Edition?
19-07-2014 11:20 PM
20-07-2014 1:46 AM
20-07-2014 7:44 AM
Quote from: starfry I just noticed a pretty-vanilla HTML file has a block of Javascript added to it...
> ... wm_group_name='/services/webpages/c/c/ccgi.jxxxxb.com/public';
Quote from: spraxyt As you speculated this JaveScript code is added (on the fly) at the end of HTML body sections for pages served to browsers.
I will preface this question with "I am not a techie" : / but does that mean that the absolute path and the username are both disclosed (ie visible by anyone viewing page source). I had thought (in relation to php/MySQL especially) that things like absolute paths were ideally not disclosed (?)
If there's no risk in that, perhaps someone could explain, thanks.
Regards,
Penny.
21-07-2014 12:38 AM
However when PHP error messages are suppressed to avoid exposing file paths it seems odd to give them in page source.
David
21-07-2014 10:11 AM
22-07-2014 11:19 PM
Quote from: Bob If people consider the file path to be a major issue then I can query it with Hostopia, however I suspect it's likely to involve a bit of work to obfuscate the information.
I wouldn't want to cause work for anyone, and I suppose hostopia must think it's not a security risk or they wouldn't present the information in that way. I'm quite glad I asked, though - technical factors are always something of a challenge - and appreciate the replies. As luck would have it, Web Analytics wasn't originally installed for our ccgi, so it's probably best I leave things as they are.
Regards,
Penny.
26-08-2014 10:33 AM
I think code added after the closing tag can trigger a malware warning in some security packages, or at least it could a few years ago. It may be that the system has been whitelisted since.
26-08-2014 10:42 AM
14-02-2016 4:16 PM
- Control Panel \ Manage Websites \ Web Analytics \ Advanced Tab (top right) \ disable.
Now I have no tracking, but at least my web site is faster.
Quote from: Bob As people have explained, this is a product of the Analytics application. It can be prevented by disabling the pixel-code tracking/switching Analytics off. If people consider the file path to be a major issue then I can query it with Hostopia, however I suspect it's likely to involve a bit of work to obfuscate the information.
03-04-2016 3:46 PM
I had a slow site but now after removing the analytics, its great.
www.oakbydesign.co.uk
Richard
- Everything else
