Asus DSL-N66U any good ?
- Asus DSL-N66U any good ?
08-02-2014 12:42 PM
Want to replace my BT homehub 5 with a better modem / router , was looking at a Fritz box 3390 but also found the a
Asus DSL-N66U .....anyone have a review on this ?
Fritz box is only vdsl ...not vdsl2 like Asus .
Reviews on the net look good , after updating firmware .
Any input most appreciated
Karl
Re: Asus DSL-N66U any good ?
08-02-2014 1:01 PM
Bob
08-02-2014 1:14 PM
cheers
karl
dick:quote
08-02-2014 1:46 PM
The DG834g router was as solid as a rock and I tried several dual band routers as replacements but they all fell short with the exception of the Asus.
Bob.
08-02-2014 1:50 PM
08-02-2014 1:58 PM
Bob.
08-02-2014 5:57 PM
08-02-2014 6:29 PM
http://community.plus.net/forum/index.php/topic,117383.msg1015595.html#msg1015595
Might be worth asking one of the Digicare team (or ^Graham21 ^i]r ) if they still can be had.....
08-02-2014 7:00 PM
There's a thread here about getting the DSL-N66U working on VDSL. I don't think it was resolved...
More posts here - Looks like a couple of users got it working but the throughput wasn't very good.
08-02-2014 9:49 PM
08-02-2014 10:37 PM
Quote from: karlos103
Just for the sake of correctness, AVM say 'VDSL' in their spec. but I can assure you all this is VDSL2.
09-02-2014 12:56 AM
cheers all
12-02-2014 4:25 PM
Well got it onto net with in few minutes no problem .
Issue is - when on 5ghz wifi im getting around 10mb lower speeds compared to lan connection ....tried every setting you can think of but still same , moved router to another position and tried different firmware ...stil no different .
Says connect at 300mps and testing next to router .
On 2.4ghz on same pc or even a different pc im getting 20mb...tried all settings again still no different and connected at 300mbps .
Hardwired into lan im get a constant 52mb download ...2.4ghz im getting around 32mb download , 5ghz around 42mb ....upload speed on both is same as lan connection .
Soon as go back to my BT Homehub 5 ...wifi speeds are fine , no different to lan connecting when next to router !!
Been back to PC world and got full refund !!!
Karl
