Technicolor TG582n dropping internet connection
- Technicolor TG582n dropping internet connection
07-10-2013 1:52 PM
I'm having the same connection drop out problems as in this old thread:
http://community.plus.net/forum/index.php/topic,107463.0.html
My laptop loses internet connection, showing the Technicolour Gateway admin login page, but the signal is strong and the lights are still on the router showing internet connection. I login to the router and all is well. It drops out for 5 seconds or longer then comes back. It's infuriating! It appears to be a router problem that a lot of people have encountered with this model.
The old thread suggests there's a firmware upgrade for the router. If this fixes this issue please can you give me the details?
Message 1 of 3
(3,539 Views)
2 REPLIES 2
Re: Technicolor TG582n dropping internet connection
07-10-2013 4:59 PM
Hi tumteetum,
You've certainly had a lot of drops recently:
<img src="http://community.plus.net/visualradius/generated/image13811613845654.png"/>
Try and upgrade your firmware here - http://products.plus-payh.co.uk/firmware/
If there's no imporvement then I'd suggest running through our faults wizard - http://faults.plus.net and we'll take a closer look.
Message 2 of 3
(1,518 Views)
07-10-2013 5:21 PM
Thank you very much. Interesting to see the drops thanks.
I'll try that thank you very much for your help
Message 3 of 3
(1,518 Views)
