tg582n web and tenet interfaces not accessible using 10.2.5.2.EO
- tg582n web and tenet interfaces not accessible usi...
15-09-2013 3:43 PM
I can understand why it would do this?
Re: tg582n web and tenet interfaces not accessible using 10.2.5.2.EO
15-09-2013 4:41 PM
15-09-2013 4:53 PM
15-09-2013 5:04 PM
Well might be best to factory reset the thing and redo your personal settings. Restoring settings from a previous firmware doesn't seem to work too well and can lead to problems.
16-09-2013 8:49 AM
16-09-2013 9:02 AM
the Thompson's are slow at responding via the GUI when your changing settings though, I suspect theres a low memory problem in them meaning that each change would be best saved and then rebooting the thing ( best unplug it from the internet before you start or you could really crash your connection)
16-09-2013 1:29 PM
Also I have an FTTC connection so effectively the modem stays connected, and only authentication gets dropped, I think I have that right.
Here is my speed test results after a few router restarts yesterday and today: http://www.speedtest.net/my-result/2970206156
I have never got more than: http://www.speedtest.net/my-result/2957075285 down and: http://www.speedtest.net/my-result/2962940986 up
16-09-2013 2:02 PM
if anything else is connected to the router there is a greater chance of it not flashing the upgrade successfully.
also don't reconnect it to the internet line until after you finish putting back all your customizations or your constant restarting will trigger the DLM to screw your connection for a week.
it doesn't matter if its dsl or fibre the *recommended practice* is still the same
16-09-2013 11:02 PM
I guess I will just have to re-flash the firmware with just the PC I will use to flash it then! I hope that that will work!
16-09-2013 11:47 PM
17-09-2013 12:20 AM
17-09-2013 7:13 PM
18-09-2013 12:41 PM
Quote from: nanotm also don't reconnect it to the internet line until after you finish putting back all your customizations or your constant restarting will trigger the DLM to screw your connection for a week.
you spoke very true check my speed differences: Before: 60.26Mb/s Down 18.25Mb/s Up and After: At least its still faster than ADSL connections though so not too bad.
