Webmail Mailboxes
- Webmail Mailboxes
Webmail Mailboxes
28-06-2013 8:03 AM
Hi
New on here and new to Webmail.
Two things I find missing in in Plus Webmail
1. I have two mail boxes but when either is opened you have no indication which you are in.
2. No easy switch between mailboxes without logging out and back in.
Or am I missing something ?
Jon
Jon
Message 1 of 7
(2,408 Views)
6 REPLIES 6
Re: Webmail Mailboxes
28-06-2013 1:17 PM
Hi wharfe1,
Welcome to our community forums.
When you enter your details at http://webmail.plus.net it will take you to your main Pluisnet email address.
To go to an additional mailbox, you need to enter the following at login, i.e. Username+additionalmailboxname
You need to have the '+' symbol in between your username and additional mailbox, you'll then need to enter your password and this will log you into your additional mailbox.
Message 2 of 7
(1,013 Views)
28-06-2013 1:29 PM
Hi Chris
Thanks for your reply.
Not sure I have made my query clear.
When logged into a mail box there to view messages there is nothing I can see on the screen to confirm which box you are in. Fine if only have one mailbox but not for multiple boxes.
Switching between mail boxes involves logging out and then back into the new one. Webmail I used previously provides a dropdown window in any mailbox you happen to be in showing the other mailboxes you can switch to without logging out.
Any chance Plus net can offer these facilities ?
Regards
Regards
Message 3 of 7
(1,013 Views)
28-06-2013 4:12 PM
It's due to security purposes, as it's a different email address you do need to login separately to that account.
You could add multiple email address in an email client that would allow you to use a drop down and choose which email address to send from.
Message 4 of 7
(1,013 Views)
30-06-2013 10:06 AM
Hi Chris
Thanks for your reply. Is there any way to add to the mailbox header ? some text to show which mailbox I am in at the time ?
Regards
Jon
Regards
Jon
Message 5 of 7
(1,013 Views)
30-06-2013 12:30 PM
One option is to create a folder in each mailbox whose name is specific to that mailbox. The folder list on the left will then enable the mailbox to be identified. (The folder can remain empty, just there for identification.)
To create a folder, click the gearwheel button bottom left and select Manage folders.
Click the + button that appears, type in the name and click Save.
David
Message 6 of 7
(1,013 Views)
01-07-2013 8:58 PM
Thanks Spraxyt. Good Idea.
Regards
Jon
Regards
Jon
Message 7 of 7
(1,013 Views)
