Tracert's to ntp.plus.net
Anotherone
Champion
Fixes: 21
I decided that is was worth starting a thread on this topic as a result of several queries that have cropped up recently, the most recent was http://community.plus.net/forum/index.php/topic,115182.msg993273.html#msg993273
I'm currently on a different Gateway and get the following -
>ping ntp.plus.net
Pinging ntp.plus.net [212.159.6.10] with 32 bytes of data:
Ping statistics for 212.159.6.10:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
>tracert ntp.plus.net
Tracing route to ntp.plus.net [212.159.6.10]
over a maximum of 30 hops:
  1    <1 ms    <1 ms    <1 ms  dsldevice.lan [192.168.1.254]
  2    34 ms    35 ms    50 ms  lo0-central10.ptw-ag02.plus.net [195.166.128.196]
  3    35 ms    34 ms    34 ms  link5-central10.ptw-gw01.plus.net [84.93.248.40]
  4    34 ms    41 ms    33 ms  56.core.plus.net [212.159.1.56]
  5    34 ms    33 ms    33 ms  te9-4.ptn-gw01.plus.net [195.166.129.33]
  6    34 ms    34 ms    34 ms  vl55.ptn-lb02.plus.net [212.159.2.125]
  7    34 ms    33 ms    34 ms  cdns02.plus.net [212.159.6.10]
Trace complete.
>tracert 212.159.6.10
Tracing route to cdns02.plus.net [212.159.6.10]
  2    34 ms    40 ms    34 ms  lo0-central10.ptw-ag02.plus.net [195.166.128.196]
  3    35 ms    35 ms    40 ms  link5-central10.ptw-gw01.plus.net [84.93.248.40]
  4    67 ms    34 ms    38 ms  56.core.plus.net [212.159.1.56]
  5    34 ms    34 ms    34 ms  te9-4.ptn-gw01.plus.net [195.166.129.33]
  6    35 ms    34 ms    34 ms  vl55.ptn-lb02.plus.net [212.159.2.125]
  7    34 ms    34 ms    34 ms  cdns02.plus.net [212.159.6.10]
Trace complete.
>tracert 212.159.6.9
Tracing route to cdns01.plus.net [212.159.6.9]
  2    34 ms    35 ms    38 ms  lo0-central10.ptw-ag02.plus.net [195.166.128.196]
  3    35 ms    34 ms    35 ms  link3-central10.ptw-gw01.plus.net [84.93.248.36]
  4    34 ms    34 ms    33 ms  56.core.plus.net [212.159.1.56]
  6    34 ms    34 ms    35 ms  vl55.ptn-lb02.plus.net [212.159.2.125]
  7    34 ms    34 ms    34 ms  cdns01.plus.net [212.159.6.9]
Trace complete.
>tracert 212.159.13.50
Tracing route to cdns02.plus.net [212.159.13.50]
  2    45 ms    37 ms    38 ms  lo0-central10.ptw-ag02.plus.net [195.166.128.196]
  3    34 ms    34 ms    34 ms  link5-central10.ptw-gw01.plus.net [84.93.248.40]
  4    34 ms    34 ms    34 ms  56.core.plus.net [212.159.1.56]
  5    34 ms    35 ms    34 ms  te9-4.ptn-gw01.plus.net [195.166.129.33]
  7    34 ms    33 ms    46 ms  cdns02.plus.net [212.159.13.50]
Trace complete.
>tracert 212.159.13.49
Tracing route to cdns01.plus.net [212.159.13.49]
  2    42 ms    97 ms    45 ms  lo0-central10.ptw-ag02.plus.net [195.166.128.196]
  3    34 ms    34 ms    34 ms  link11-central10.ptw-gw01.plus.net [84.93.248.52]
  5    34 ms    34 ms    33 ms  te9-4.ptn-gw01.plus.net [195.166.129.33]
  6  104 ms    33 ms    34 ms  vl55.ptn-lb02.plus.net [212.159.2.125]
  7    33 ms    34 ms    34 ms  cdns01.plus.net [212.159.13.49]
Trace complete.
All the above were done yesterday. I couldn't recall if pings or tracerts to ntp.plus.net always went to the same cdns server just for hours (which it certainly does) or days or until I change Gateway. Well all the above are the same today (no Gateway change yet).
You'll note that all the routes are identical apart from hop 3, should this happen,  is this right/correct?
What happens if any of the Routers in hops 4, 5, & 6 fail - No DNS it would seem  Shocked
An issue about common subnets and paths was mentioned here -
http://community.plus.net/forum/index.php/topic,110965.msg951189.html#msg951189
but there was no Plusnet response to these specific points.
We'll see what some Gateway hopping yields.
31 REPLIES 31
ejs
Aspiring Hero
Fixes: 25
Re: Tracert's to ntp.plus.net
I'm guessing ntp.plus.net sticking to one IP address has something to do with DNS caching on your computer or local network, and is unrelated to the traceroutes.
Just for reference:
[tt]traceroute -I 212.159.6.9
traceroute to 212.159.6.9 (212.159.6.9), 30 hops max, 60 byte packets
1  192.168.0.1 (192.168.0.1)  3.229 ms  3.317 ms  3.886 ms
2  lo0-central10.ptw-ag01.plus.net (195.166.128.195)  20.823 ms  22.395 ms  24.848 ms
3  link7-central10.ptw-gw01.plus.net (84.93.248.12)  24.609 ms  26.380 ms  28.375 ms
4  xe-0-2-0.ptw-cr01.plus.net (212.159.1.16)  28.595 ms  29.913 ms  30.518 ms
5  te9-4.ptn-gw01.plus.net (195.166.129.33)  32.195 ms  33.153 ms  34.570 ms
6  vl55.ptn-lb02.plus.net (212.159.2.125)  35.637 ms  35.935 ms  35.977 ms
7  cdns01.plus.net (212.159.6.9)  36.060 ms  19.763 ms  19.994 ms
traceroute -I 212.159.13.49
traceroute to 212.159.13.49 (212.159.13.49), 30 hops max, 60 byte packets
1  192.168.0.1 (192.168.0.1)  3.065 ms  5.367 ms  5.573 ms
2  lo0-central10.ptw-ag01.plus.net (195.166.128.195)  21.744 ms  23.298 ms  25.353 ms
3  link7-central10.ptw-gw01.plus.net (84.93.248.12)  26.014 ms  26.974 ms  27.706 ms
4  xe-0-2-0.ptw-cr01.plus.net (212.159.1.16)  28.439 ms  30.749 ms  30.956 ms
5  te9-4.ptn-gw01.plus.net (195.166.129.33)  32.476 ms  33.566 ms  34.687 ms
6  vl55.ptn-lb02.plus.net (212.159.2.125)  47.099 ms  44.525 ms  44.945 ms
7  cdns01.plus.net (212.159.13.49)  45.013 ms  29.016 ms  30.375 ms
traceroute -I 212.159.6.10
traceroute to 212.159.6.10 (212.159.6.10), 30 hops max, 60 byte packets
1  192.168.0.1 (192.168.0.1)  1.841 ms  4.368 ms  5.825 ms
2  lo0-central10.ptw-ag01.plus.net (195.166.128.195)  116.710 ms  117.145 ms  119.568 ms
3  link3-central10.ptw-gw01.plus.net (84.93.248.4)  26.033 ms  27.616 ms  28.471 ms
4  xe-0-2-0.ptw-cr01.plus.net (212.159.1.16)  29.683 ms  30.280 ms  37.702 ms
5  te9-4.ptn-gw01.plus.net (195.166.129.33)  32.968 ms  34.436 ms  37.107 ms
6  vl55.ptn-lb02.plus.net (212.159.2.125)  59.976 ms  58.795 ms  57.644 ms
7  cdns02.plus.net (212.159.6.10)  40.814 ms  26.834 ms  27.494 ms
traceroute -I 212.159.13.50
traceroute to 212.159.13.50 (212.159.13.50), 30 hops max, 60 byte packets
1  192.168.0.1 (192.168.0.1)  2.982 ms  3.043 ms  3.210 ms
2  lo0-central10.ptw-ag01.plus.net (195.166.128.195)  21.514 ms  22.583 ms  24.385 ms
3  link3-central10.ptw-gw01.plus.net (84.93.248.4)  25.128 ms  26.045 ms  27.580 ms
4  xe-0-2-0.ptw-cr01.plus.net (212.159.1.16)  28.035 ms  29.719 ms  30.318 ms
5  te9-4.ptn-gw01.plus.net (195.166.129.33)  32.113 ms  32.570 ms  34.183 ms
6  vl55.ptn-lb02.plus.net (212.159.2.125)  36.167 ms  33.732 ms  34.449 ms
7  cdns02.plus.net (212.159.13.50)  35.837 ms  18.475 ms  19.221 ms
[/tt]
30FTTC06
Fixes: 4
here is mine if it helps.
pcl-ag03
>ping ntp.plus.net
Reply from 212.159.6.10: bytes=32 time=18ms TTL=250
Approximate round trip times in milli-seconds:
    Minimum = 18ms, Maximum = 18ms, Average = 18ms
Tracing route to ntp.plus.net [212.159.13.49]
  1    55 ms    99 ms    99 ms  192.168.0.254
  2    35 ms    20 ms    27 ms  lo0-central10.pcl-ag03.plus.net [195.166.128.184]
  3    17 ms    17 ms    17 ms  link9-central10.pcl-gw01.plus.net [84.93.249.80]
  4    17 ms    17 ms    17 ms  xe-1-2-0.pcl-cr01.plus.net [212.159.1.4]
  5    17 ms    17 ms    17 ms  po2.pcl-gw01.plus.net [195.166.129.41]
  6    18 ms    18 ms    17 ms  vl63.pcl-lb02.plus.net [212.159.2.253]
  7    18 ms    20 ms    17 ms  cdns01.plus.net [212.159.13.49]
Trace complete.
  2    18 ms    17 ms    17 ms  lo0-central10.pcl-ag03.plus.net [195.166.128.184]
  3    18 ms    17 ms    17 ms  link7-central10.pcl-gw01.plus.net [84.93.249.76]
  4    17 ms    16 ms    17 ms  xe-1-2-0.pcl-cr01.plus.net [212.159.1.4]
  5    17 ms    18 ms    17 ms  po2.pcl-gw01.plus.net [195.166.129.41]
  6    18 ms    18 ms    18 ms  vl63.pcl-lb02.plus.net [212.159.2.253]
  7    18 ms    17 ms    17 ms  cdns02.plus.net [212.159.6.10]
Trace complete.
>tracert 212.159.6.9
  1    30 ms    98 ms    99 ms  192.168.0.254
  2    20 ms    27 ms    20 ms  lo0-central10.pcl-ag03.plus.net [195.166.128.184]
  3    17 ms    17 ms    18 ms  link9-central10.pcl-gw01.plus.net [84.93.249.80]
  6    31 ms    17 ms    17 ms  vl63.pcl-lb02.plus.net [212.159.2.253]
  7    22 ms    18 ms    19 ms  cdns01.plus.net [212.159.6.9]
Trace complete.
  1    69 ms    99 ms    99 ms  192.168.0.254
  2    18 ms    19 ms    19 ms  lo0-central10.pcl-ag03.plus.net [195.166.128.184]
  3    17 ms    18 ms    17 ms  link7-central10.pcl-gw01.plus.net [84.93.249.76]
  5    18 ms    17 ms    17 ms  ae1.ptw-cr01.plus.net [195.166.129.0]
  6    18 ms    18 ms    18 ms  te9-4.ptn-gw01.plus.net [195.166.129.33]
  7    18 ms    18 ms    18 ms  vl55.ptn-lb02.plus.net [212.159.2.125]
  8    17 ms    18 ms    17 ms  cdns02.plus.net [212.159.13.50]
Trace complete.
  1    85 ms    99 ms    99 ms  192.168.0.254
  2    18 ms    21 ms    71 ms  lo0-central10.pcl-ag03.plus.net [195.166.128.184]
  3    18 ms    17 ms    17 ms  link9-central10.pcl-gw01.plus.net [84.93.249.80]
  4    19 ms    17 ms    17 ms  xe-1-2-0.pcl-cr01.plus.net [212.159.1.4]
  6    18 ms    18 ms    19 ms  vl63.pcl-lb02.plus.net [212.159.2.253]
  7    20 ms    18 ms    18 ms  cdns01.plus.net [212.159.13.49]
Anotherone
Champion
Fixes: 21
@30FTTC06
Now there is interesting, your tracert 212.159.13.50 has an extra hop with hop 5 onwards being different from the others.
@ejs
Ha, tracert to ntp.plus.net using the same cdns IP possibly due to DNS caching - had just twigged that possibility myself having just sat in front of another computer and it's using a different one from the other computer (no Gateway change yet). Will investigate a bit further.
30FTTC06
Fixes: 4
I always thought i was special  Grin
ok i'll get me coat..
Anotherone
Champion
Fixes: 21
With your ping, you certainly are  Lips_are_sealed
Flushing the DNS Cache sorted the cdns IP address point, it became random if flushed each time, however no change to the hops on the current gateway.
ejs
Aspiring Hero
Fixes: 25
pcl-ag01, all four routes are slightly different, to .13.50 more so
[tt]# traceroute -I 212.159.6.9
1  192.168.0.1 (192.168.0.1)  2.322 ms  3.701 ms  4.224 ms
2  lo0-central10.pcl-ag01.plus.net (195.166.128.182)  70.621 ms  72.046 ms  73.454 ms
link3-central10.pcl-gw01.plus.net (84.93.249.4)  25.333 ms  27.163 ms  29.365 ms
4  192.core.access.plus.net (212.159.0.192)  29.866 ms  31.208 ms  31.958 ms
5  po2.pcl-gw01.plus.net (195.166.129.41)  33.389 ms  35.334 ms  36.468 ms
6  vl63.pcl-lb02.plus.net (212.159.2.253)  38.246 ms  37.404 ms  37.946 ms
7  cdns01.plus.net (212.159.6.9)  39.272 ms  20.705 ms  19.840 ms
# traceroute -I 212.159.13.49
1  192.168.0.1 (192.168.0.1)  3.232 ms  3.390 ms  3.772 ms
2  lo0-central10.pcl-ag01.plus.net (195.166.128.182)  21.594 ms  27.208 ms  29.895 ms
link9-central10.pcl-gw01.plus.net (84.93.249.16)  26.454 ms  29.701 ms  30.548 ms
4  192.core.access.plus.net (212.159.0.192)  31.076 ms  31.949 ms  33.133 ms
5  po2.pcl-gw01.plus.net (195.166.129.41)  35.902 ms  36.241 ms  37.921 ms
6  vl63.pcl-lb02.plus.net (212.159.2.253)  39.764 ms  38.800 ms  40.101 ms
7  cdns01.plus.net (212.159.13.49)  40.602 ms  24.615 ms  20.535 ms
# traceroute -I 212.159.6.10
1  192.168.0.1 (192.168.0.1)  3.324 ms  3.568 ms  3.796 ms
2  lo0-central10.pcl-ag01.plus.net (195.166.128.182)  22.418 ms  24.159 ms  24.774 ms
link5-central10.pcl-gw01.plus.net (84.93.249.8 )  25.623 ms  27.614 ms  28.287 ms
4  192.core.access.plus.net (212.159.0.192)  29.861 ms  31.448 ms  32.229 ms
5  po2.pcl-gw01.plus.net (195.166.129.41)  34.716 ms  35.720 ms  37.351 ms
6  vl63.pcl-lb02.plus.net (212.159.2.253)  39.732 ms  37.356 ms  38.130 ms
7  cdns02.plus.net (212.159.6.10)  39.540 ms  24.461 ms  25.614 ms
# traceroute -I 212.159.13.50
1  192.168.0.1 (192.168.0.1)  3.055 ms  3.219 ms  3.767 ms
2  lo0-central10.pcl-ag01.plus.net (195.166.128.182)  22.528 ms  24.070 ms  24.646 ms
3  link5-central10.pcl-gw01.plus.net (84.93.249.8 )  26.944 ms  27.330 ms  28.293 ms
4  192.core.access.plus.net (212.159.0.192)  29.837 ms  31.722 ms  32.275 ms
5  ae1.ptw-cr01.plus.net (195.166.129.0)  34.382 ms  36.757 ms  37.402 ms
6  te9-4.ptn-gw01.plus.net (195.166.129.33)  38.734 ms  35.979 ms  37.505 ms
7  vl55.ptn-lb02.plus.net (212.159.2.125)  38.859 ms  21.151 ms  22.491 ms
8  cdns02.plus.net (212.159.13.50)  23.271 ms  22.188 ms  22.908 ms
[/tt]
paulmh5
Quote from: Anotherone
In answer to your question about hop 3, yes thats fine and expected.  In summery you have 12 links to pick from and route hashing will just send you off down one of them.  All the other hops are resilient in one format or another and will be routed around.
In regards to the DNS servers.  We have them (cluster) located in two sites, both responding to the same VIP ranges so in theory you should just go to the cloest one, if one site goes away the same VIP will just work at the other site.
Hopefully that helps a little, if I've missed the point in some way or there is an issue I'm sure the DC guys will pick it up and/or get it logged internally.
Plusnet Staff - Lead Network Design/Delivery Engineer
Anotherone
Champion
Fixes: 21
Thanks for the reply Paul, sorry that was a badly phrased question, the question really should have been phrased - apart from hop 3, is it right that the rest of the routes are identical - is this right/correct? The question wasn't about hop 3.
Can you explain how this "resilience" is supposed to work. In the tracert's I've posted from ptw-ag02, hops 4.5.& 6 are identical.
The question is "What happens if any of the Routers in hops 4, 5, & 6 fail" as those routes to each of the cdns servers is identical.
Anotherone
Champion
Fixes: 21
Here's tracert's from pcl-ag01 that I managed to get onto this morning -
 2    35 ms    40 ms    35 ms  lo0-central10.pcl-ag01.plus.net [195.166.128.182]
 3    34 ms    33 ms    34 ms  link9-central10.pcl-gw01.plus.net [84.93.249.16]
 4    34 ms    33 ms    33 ms  192.core.access.plus.net [212.159.0.192]
 5    34 ms    33 ms    33 ms  po2.pcl-gw01.plus.net [195.166.129.41]
 6    34 ms    34 ms    34 ms  vl63.pcl-lb02.plus.net [212.159.2.253]
 7    33 ms    33 ms    34 ms  cdns01.plus.net [212.159.13.49]
Trace complete.
 2    40 ms    36 ms    34 ms  lo0-central10.pcl-ag01.plus.net [195.166.128.182]
 3    34 ms    34 ms    33 ms  link1-central10.pcl-gw01.plus.net [84.93.249.0]
 4    34 ms    34 ms    33 ms  192.core.access.plus.net [212.159.0.192]
 5    33 ms    34 ms    34 ms  ae1.ptw-cr01.plus.net [195.166.129.0]
 6    34 ms    33 ms    33 ms  te9-4.ptn-gw01.plus.net [195.166.129.33]
 7    34 ms    34 ms    33 ms  vl55.ptn-lb02.plus.net [212.159.2.125]
 8    34 ms    34 ms    33 ms  cdns02.plus.net [212.159.13.50]
Trace complete.
>tracert 212.159.6.9
 2    37 ms    40 ms    34 ms  lo0-central10.pcl-ag01.plus.net [195.166.128.182]
 3    34 ms    33 ms    33 ms  link9-central10.pcl-gw01.plus.net [84.93.249.16]
 4    34 ms    34 ms    32 ms  192.core.access.plus.net [212.159.0.192]
 5    34 ms    34 ms    33 ms  po2.pcl-gw01.plus.net [195.166.129.41]
Trace complete.
 2    35 ms    34 ms    34 ms  lo0-central10.pcl-ag01.plus.net [195.166.128.182]
 3    34 ms    34 ms    34 ms  link1-central10.pcl-gw01.plus.net [84.93.249.0]
 4   108 ms    33 ms    36 ms  192.core.access.plus.net [212.159.0.192]
 6    34 ms    33 ms    34 ms  vl63.pcl-lb02.plus.net [212.159.2.253]
Trace complete.
Hmm, interesting, hops 4, 5, & 6 are the same except for cdns02.plus.net [212.159.13.50] where after hop 4 it's different, with an extra hop!!
I notice the same in ejs's last post also pcl-ag01.
Anotherone
Champion
Fixes: 21
Tracert's from ptw-ag04
  2    40 ms    43 ms    38 ms  lo0-central10.ptw-ag04.plus.net [195.166.128.194]
  3    37 ms    37 ms    37 ms  link7-central10.ptw-gw01.plus.net [84.93.248.108]
  4    37 ms    47 ms    39 ms  xe-10-0-0.ptw-cr01.plus.net [212.159.1.40]
  5    37 ms    37 ms    37 ms  te9-4.ptn-gw01.plus.net [195.166.129.33]
  6    37 ms    37 ms    36 ms  vl55.ptn-lb02.plus.net [212.159.2.125]
  7    37 ms    37 ms    37 ms  cdns01.plus.net [212.159.13.49]
Trace complete.
  2    38 ms    37 ms    40 ms  lo0-central10.ptw-ag04.plus.net [195.166.128.194]
  3    38 ms    37 ms    37 ms  link1-central10.ptw-gw01.plus.net [84.93.248.96]
  4    36 ms    37 ms    37 ms  xe-10-0-0.ptw-cr01.plus.net [212.159.1.40]
  5    38 ms    37 ms    37 ms  te9-4.ptn-gw01.plus.net [195.166.129.33]
  7    37 ms    37 ms    37 ms  cdns02.plus.net [212.159.13.50]
Trace complete.
>tracert 212.159.6.9
  2    67 ms    39 ms    47 ms  lo0-central10.ptw-ag04.plus.net [195.166.128.194]
  3    37 ms    37 ms    50 ms  link7-central10.ptw-gw01.plus.net [84.93.248.108]
  4    37 ms    40 ms    36 ms  xe-10-0-0.ptw-cr01.plus.net [212.159.1.40]
  6    37 ms    37 ms    37 ms  vl55.ptn-lb02.plus.net [212.159.2.125]
  7    36 ms    37 ms    36 ms  cdns01.plus.net [212.159.6.9]
Trace complete.
  2    37 ms    38 ms    41 ms  lo0-central10.ptw-ag04.plus.net [195.166.128.194]
  3    37 ms    36 ms    37 ms  link1-central10.ptw-gw01.plus.net [84.93.248.96]
  4    37 ms    37 ms    36 ms  xe-10-0-0.ptw-cr01.plus.net [212.159.1.40]
  5    37 ms    36 ms    37 ms  te9-4.ptn-gw01.plus.net [195.166.129.33]
  6    38 ms    37 ms    37 ms  vl55.ptn-lb02.plus.net [212.159.2.125]
  7    37 ms    37 ms    37 ms  cdns02.plus.net [212.159.6.10]
Trace complete.
Hops 4 to 6 identical to all. As my normal DNS servers are set to 212.159.6.9 & 10 automatically,  it seems to me if any other those 3 Routers fail to respond, I get a failed DNS lookup!
Fixes: 160
Quote from: paulmh5
Paul,
Is the point you are trying to make here, is that the IP addresses we see in trace routes to PN services are virtual, not the real addresses of the servers?  Therefore if a real server / route is not available, the network will redirect the virtual IP to a different physical server delivering the same service?
Cheers,
Kevin
Anotherone
Champion
Fixes: 21
The impression that I've always been given, which I thought is what Paul appeared to be saying is that  212.159.6.9 & 10 and 212.159.13.49 & 50, although AFAIK they aren't VIP addresses, they behave like that because of the load balancer they are connected to?
But that does not explain what happens if for example xe-10-0-0.ptw-cr01.plus.net in the tracert in my previous post fails/fails to respond!
Fixes: 160
Anotherone,
Agreed!  This does not look clear to us outsiders.  Many 'alternate' PN network services appear to have the same connectivity route within their network, thus (at least superficially) the failure in one step of the common route will cause connectivity to the prime and alternate services to fail.
It would be most useful to learn / know how the primary / secondary services are indeed resilient to a failure in what appears to be common (shared) routes.
Terminology in this area does confuse me, but would I be correct in saying arguably any service behind a load balancer is virtualised?  One is not addressing the machine delivering the service, but something which will select 1 out of N instances of the service, each of which must have its own unique IP address.
Kevin
bobpullen
Fixes: 316
Quote from: townman
Quote from: paulmh5
Paul,
I'm not Paul but yes, the IP's you see in traceroutes are not those of the physical caching DNS servers themselves. They are virtual IP's. The physical caching servers themselves are clustered across two sites for resiliency. I think BGP or something similar is used to route you to the closest cluster which is the basis for the question jelv asked here.
I could be wrong but last I knew there were four physical boxes in each cluster (each with their own IP that you'll not see in traceroutes).
That's a core router (Juniper MX kit I think). The rDNS of that hop represents one of multiple interfaces on the device itself. There will be redundancy within the unit itself e.g. multiple line cards as well as there being another physical unit i.e. ptw-cr02. I don't know a huge amount about our core network but I do know there's sufficient resiliency should a network interface unexpectedly fall over.
I'm going to bow out now before I get out of my depth, however if this thread is a question of whether or not we've sufficient network redundancy then I don't think people have anything to worry about Wink
