PlusNet TG582n Network Icons
oren
As PlusNet's TG582n on ADSL does not have a USB port is there any way to disable the MediaServer icon & the TECHNICOLOR network place icon in Win7-64 as they both represent nothing useful ?
(I would have thought that this was something that would be suppressed in the PlusNet firmware as they chose to take the USB port off the ADSL routers)
9 REPLIES 9
Oldjim
Resting Legend
Fixes: 63
Re: PlusNet TG582n Network Icons
good question - I wish I knew the answer
Fixes: 396
Login to the TG582 , go to Home->Content Sharing and click on Configure, uncheck the 'Server Enabled' boxes for both the Network File Server & UPnP AV Media Server and then click Apply.
That should disable all the Content sharing functions and they should no longer appear ( may need to restart the PC and/or the router )
Hope that helps
Oldjim
Resting Legend
Fixes: 63
That link isn't there
jelv
Fixes: 10
Also the contentsharing command is disabled in the CLI.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Fixes: 396
Thanks Jelv, I was just looking at that.
Fancy disabling that, how stupid !!
npr
Fixes: 9
Is contentsharing shown in the user.ini file ?
If so try disabling it there and restoring the file.--
eg:
[ contentsharing.ini ]
cifs config state=disabled
Alternatively try running the cli command as a script, this sometimes works with commands which refuse to run.
eg:
script add name=icon command="cifs config state=disabled"
script run name=icon pars=""
saveall
Fixes: 396
I've just looked at a user.ini file from f/w 10.2.2.9 ( presumably the one with no USB ) and it has
ftp config state=disabled
cifs config state=disabled workgroup="" name="" comment=""
upnp config state=disabled friendlyname=""
upnp radiostation config state=disabled
whereas 8.4.4.J has
cifs config state=enabled workgroup=WORKGROUP name=Technicolor comment="DSL Gateway"
upnp config state=enabled friendlyname="Technicolor TG582n"
So it would appear that not only is it possible to use the content sharing commands in user.ini BUT that all the services are already disabled...
oren
Thanks for the interest and suggestions.  I'll try editing the *.ini when I've had time to research any possible down-side.
Just for the record, as I happen to also have a "vanilla" TG582n (Software Release:8.4.4.I) as well as the PlusNet one (Software Release:8.4.4.J), I can confirm that MisterW was on the right track, if PlusNet's "wisdom" hadn't got in the way and removed the option - see attached capture of the "vanilla" tools page.
The bits from the *.ini from the "vanilla" and the "PlusNet" boxes are below - with the "vanilla" USB working as a USB file server:
[ contentsharing.ini ] "vanilla" Release:8.4.4.I
ftp config state=enabled
cifs config state=enabled workgroup=MYWORKGROUP name=TG582USB comment="USB Files"
[ contentsharing.ini ] PlusNet Release:8.4.4.J with no USB
Anotherone
Champion
Fixes: 21
I can see I shall have to investigate this a bit Wink
