TG582n FTTC edition - enable PPPoA? (re: high-pitched whine)
- TG582n FTTC edition - enable PPPoA? (re: high-pitc...
16-03-2013 2:28 PM
The TG582n that was supplied when I joined Plusnet is faulty. It makes a horrible high-pitched whining noise whilst turned on, which means I have to turn it off as often as possible (very irritating and probably not great for my speed profile).
I asked for a replacement on Monday 11 March and was told one would be sent. Today a new router turned up, and, hurrah, it does not have the high-pitched whine.
However, it turns out that new router is an FTTC router, which is for the FTTP trial I'm on that will hopefully be installed on 9 April. Although this new router has a DSL port, any configuration for it is disabled in the web interface.
It would seem that the router I ordered on Monday was never dispatched.
Rather than order yet another router, which will itself need to be returned in a few weeks, is it possible to enable PPPoA on this FTTC unit?
All advice gratefully recieved.
Re: TG582n FTTC edition - enable PPPoA?
16-03-2013 2:36 PM
17-03-2013 10:10 PM
A bit nervous about flashing it tbh - was hoping it could be achieved with a few Telnet commands (changes which would then be reversed by a quick factory reset when the fibre goes live).
Also, how come the firmware images aren't hosted on a Plusnet branded URL? And the flashing tool itself is hosted on yet another URL..?
Sorry to be curmudgeonly but running executable files and installing firmwware of unknown provenance could have all sorts of very unpleasant repercussions, even if it appears to work correctly at first.
17-03-2013 10:20 PM
Quote from: mefibre The TG582n that was supplied when I joined Plusnet is faulty. It makes a horrible high-pitched whining noise whilst turned on, which means I have to turn it off as often as possible (very irritating and probably not great for my speed profile).
Just noticed your post. Yet another person who got a router that makes a high-pitched noise. Seeing as you could hear it and you got a replacement that doesn't make the noise I have to revise my conclusion that only certain people can hear it; that it is actually only certain routers that make the noise. I've had four routers and they all whistle.
17-03-2013 10:31 PM
Previously on Be with a silent TG582n. Before returning that router I ran it side-by-side with the original Plusnet router and the difference was very clearly audible.
Likewise, the new FTTC-configured Plusnet router is silent.
I suspect a bad batch is around at the moment...
dick:quote
18-03-2013 9:05 AM
18-03-2013 9:23 AM
I suspect the difference is just that this one came from a different manufacturing batch.
dick:quote
18-03-2013 9:44 AM
Quote from: mefibre Also, how come the firmware images aren't hosted on a Plusnet branded URL?
They are (kind of):
bpullen@pvs-csctools:~$ whois plus-payh.co.uk
[Querying whois.nic.uk]
[whois.nic.uk]
Domain name:
plus-payh.co.uk
Registrant:
Plusnet PLC
Registrant type:
Unknown
Registrant's address:
The Balance
2 Pinfold Street
Sheffield
South Yorkshire
S1 2GU
United Kingdom
Registrar:
Plusnet Plc t/a Just-the-Name [Tag = GETSURFED]
URL: http://www.just-the-name.co.uk
Relevant dates:
Registered on: 02-Jan-2008
Expiry date: 02-Jan-2014
Last updated: 01-May-2012
Registration status:
Registered until expiry date.
Name servers:
ns0.payh.co.uk 212.56.83.195
ns1.payh.co.uk 212.56.83.227
GETSURFED is the IPSTag for Just-The-Name who are one of our sister companies offering domain registration. The name servers ns0.payh.co.uk and ns1.payh.co.uk belong to Pay As You Host, another sister company offering hosting services.
Quote from: mefibre And the flashing tool itself is hosted on yet another URL..?
That's the Plusnet homepages servers. The binarybob account is actually one of mine.
Quote Sorry to be curmudgeonly but running executable files and installing firmwware of unknown provenance could have all sorts of very unpleasant repercussions, even if it appears to work correctly at first.
You needn't doubt the authenticity of the files.
18-03-2013 9:56 AM
Quote from: Bob You needn't doubt the authenticity of the files.
Thanks for all the background info. I had noticed that it was apparently a Plusnet registered domain and a Plusnet homepage, but I was still puzzled that it's not all just listed in the Support Library pages, as it was for the older routers (link). That would make it seem much more above board! However I'm happy to trust that it's kosher.
Re: TG582n FTTC edition - enable PPPoA? (re: high-pitched whine)
18-03-2013 10:45 AM
18-03-2013 11:25 AM
Ex-Broadband Service Manager
18-03-2013 12:05 PM
Quote from: Anotherone Once you've flashed the router back to the ADSL modem/router, you can convert to Fibre without reflashing following the instructions at http://community.plus.net/forum/index.php/topic,106578.msg914793.html#msg914793 ; BUT note http://community.plus.net/forum/index.php/topic,106578.msg961176.html#msg961176
That's very interesting. It suggests that with the FTTC firmware and the right config changes, the router could be modified to connect over ADSL.
The "USB caveat" on modifying the ADSL firmware config for use on FTTC is unfortunate - I will probably end up flashing back to the FTTC firmware 8.C.M.0 in order to retain the use of the USB port.
18-03-2013 12:07 PM
18-03-2013 12:19 PM
Quote from: Kelly Is it the router or the PSU that is whistling?
The router is the culprit. The PSU does whistle but only if you put your ear next to it.
I have tried swapping PSUs (my old Be PSU and the new PSU from the FTTC-configured router do not whistle even when you put your ear to them) but the router still whistles, even when a quiet PSU is used...
18-03-2013 12:24 PM
Quote from: Anotherone That might depend on which ADSL firmware version you use, but Matt Turner would be the guy to answer that.
Cheers for the tip - I'll send him a message.
