Sync drops when phone rings (subject was "Is this a record?)
- Sync drops when phone rings (subject was "Is this ...
15-03-2013 1:38 PM
The router stats noise margin often has these switches from a stable noise margin to a highly variable noise margin (see attached) and then some hours later (or even the next day) goes back to stable with minimal variation. Has anyone seen anything like that before? If it was something like REIN I'd expect it to drop significantly when it became unstable.
Second issue is that the connection drops when there is an incoming call.
The master socket is in a totally useless position in the lounge - not even anywhere near the television.
That brings me to the subject of this post. There are telephone extension sockets in three bedrooms (one of which is my office), the hall, kitchen, dining room and a second socket in the lounge - that's master socket plus SEVEN extensions. I suspect that might have something to do with my problems!
PS I bet my radius graph is a mess!
Re: Is this a record?
15-03-2013 2:14 PM
Get some fresh and start again... ask the local cable/openreach man in a van for some jelly crimps and buy some cat5e and a crone tool etc.
15-03-2013 2:25 PM
Post up the Bits/Tone allocations for each condition when you have it. It won't have anything to do with all your extensions. Just make sure all the wiring is CW1308 and no bell wire. I'll post more later tonight. I've got things to add to the 582n threads as well when I get time to compile it.
Which modem/router are you using at the moment?
15-03-2013 2:37 PM
Quote from: Anotherone Just make sure all the wiring is CW1308 and no bell wire
They are all fully wired at the moment. I'm thinking I'm doing well to hold the IP Profile at 6MB (attenuation is 22.5). The phone is a DECT so I've just tried adding a second filter.
I'm currently trying to work out the possibility of running Cat 5e from the lounge to the office and getting this.
Quote from: Anotherone Which modem/router are you using at the moment?
Back on the TG582.
16-03-2013 9:15 PM
Most annoyingly I had this very same problem 4 days ago when I connected after being off-line, but I didn't save any Plots. I had to resync twice to get a nice SNRM, it doesn't happen that often thank goodness.
So attached is one graph I dug up from a year ago, and another from last August, but neither as wild a variation as I've had recently or previously, or as you've just had.
Also attached is a Bits/Tone from someone else's line showing a gap with only 2 bits at ~tone193, and my current one with a gap with only 2 bits at tone 126.
Mine is not looking too clever at them moment as there's a lot of bit swapping going on, not shown on the graph. A daytime one looks a lot cleaner. Note the gap at tone 64 is the pilot, tones 211, 252 & 253 are due to broadcast stations.
The gap at tone 193 in the first graph and 126 in the second can be on a different tone at sync, anywhere on the downstream. The closer to the pilot, slightly lower the sync. It's unpredictable and has something to do with an interaction between BDCM chipsets in the modem/router and TI (TSTC) chipset in the 20CN DSLAM.
You will notice that you won't have the gap with a tone only having 2 bits when you have the wild SNRM. A delightful "feature".
Final attachments are my typical SNRM plots, a not perfectly "quiet" day and a night-time.
As far as your wiring goes, if it's all CW1308, well you know the drill - drop the PPP, power down, unplug. Carefully remove wires from terminals 3 & 4 throughout, check you don't have a split pair - ie. make sure Blue+white trace is on 2 and White+blue trace is on 5 throughout.
If you have old cable anywhere the colours would be Blue, Orange, Green & Brown then it's either a re-wire or filtered faceplate and separate cable to your modem/router location. What you suggested in your previous reply would work but Cat5e is an over-kill, CW1308 will do (unless FTTC is coming) and your suggestion is a sledge hammer to crack a nut if all your existing wiring is CW1308.
20-03-2013 9:46 AM
I've now got a long Ethernet cable dangling over the banister so that I can put the router in to the test socket (so the 'aerial farm' is totally disconnected).
Sync is still being lost when the phone rings. I've tried a different filter.
Just got to try a different phone (currently using a DECT phone) and no phone plugged in at all.
20-03-2013 10:23 AM
20-03-2013 11:58 AM
I've certainly seen worse radius graphs:
<img src="http://ccgi.psmith12.plus.com/visradius/generated/image13637806059196.png"/>
I've also nudged your profile up to 6500 to match BTs side, hope that helps.
20-03-2013 11:59 AM
OK, time to raise a fault:
There's been a problem
Please try using the Broadband Troubleshooter again in a short while. If you continue to have problems please contact our Support Team for help.
20-03-2013 12:01 PM
Quote from: Matt Hi jelv,
<snipped>
This is something I've seen a few times. If the sync is restored quickly the PPP session doesn't drop and it doesn't show on your graph. Can you see a log of the BT sync times?
Quote from: Matt I've also nudged your profile up to 6500 to match BTs side, hope that helps.
20-03-2013 12:01 PM
20-03-2013 12:03 PM
20-03-2013 12:32 PM
20-03-2013 3:51 PM
20-03-2013 4:05 PM
