Gateway madness!
- Gateway madness!
Gateway madness!
21-02-2013 2:01 PM
I am often switched gateway between London and an area between Yorkshire and midlands (Nottingham area) It is driving me crazy!!! Even worse my neighbour (BT Infinity) has her gateway up here in the north east! why is it in different locations? When I was with sky ADSL+2 my location was up in north east as well. So why is my location LONDON when i clearly live in Newcastle upon Tyne! The gateway i am now is pcl-ag03 I check this at http://usertools.plus.net/@gateway/
Jamie
Re: Gateway madness!
21-02-2013 2:13 PM
21-02-2013 2:17 PM
http://www.kitz.co.uk/isp/pnPipes.htm
21-02-2013 2:34 PM
Jamie
21-02-2013 3:25 PM
Geordiegal: I think you don't actually need to worry about gateway location. It sounds like you've got a fault or something that needs fixing?
What's the problem?
Ex-Broadband Service Manager
21-02-2013 3:26 PM
21-02-2013 3:38 PM
<img src="http://ccgi.psmith12.plus.com/visradius/generated/image13614610756338.png"/>
If they're not then I'd recommend raising a fault at http://faults.plus.net to get that looked into
21-02-2013 4:58 PM
Yes these are manual reboots.
@Dvorak
I am using www.speedtest.net and this locates me i'm in London where i'm actually in Newcastle Tyne. When I type telehouse north it locates for London.
21-02-2013 5:08 PM
So it will run tests to the server located in Newcastle in this instance.
21-02-2013 5:11 PM
21-02-2013 5:17 PM
21-02-2013 9:33 PM
21-02-2013 10:00 PM
21-02-2013 10:38 PM
Does this matter if i have fibre?? Its because I have fibre not ADSL
Quote from: Kelly Your ADSL connection goes into the exchange and then is tunnelled through the BT 21CN network. It appears in London at one of our datacentres in Telehouse or Citylifeline. To the rest of the internet, it appears that your IP address is from London
22-02-2013 9:58 AM
It only affects the way it gets from your cab to the exchange after that it follows the same route as the non fibre traffic
