TBB Pings Graphs - issues arising
- TBB Pings Graphs - issues arising
20-01-2013 6:07 PM
There's nothing I'm doing that would explain the high latency around 5pm nor the high latency yesterday evening.
(4am to 9:30am is because the local electricty sub-station blew up!)
Re: TBB Pings Graphs - issues arising
20-01-2013 6:10 PM
Ex-Broadband Service Manager
20-01-2013 6:10 PM
21-01-2013 7:34 PM
For these graphs to have real benefit, do you not need to know which PN gateway a user is connected to at all times? Or do you have other TBB graphs hidden away somewhere showing ping times into each gateway? If yes, it would be good if we could see those too please.
21-01-2013 11:35 PM
22-01-2013 4:48 PM
Quote from: townman Kelly / Chris,
It's not really as simple as just looking at the gateway due to the config of the network, it can help give us a general idea though. We can already see which gateway you're connected to by looking in our RADIUS logs.
22-01-2013 8:25 PM
Tracing route to google.com [173.194.41.78]
over a maximum of 30 hops:
1 4 ms 3 ms 3 ms netgear.houlton23.local [192.168.1.254]
2 23 ms 20 ms 19 ms lo0-central10.pcl-ag05.plus.net [195.166.128.186
3 21 ms 22 ms 22 ms link7-central10.pcl-gw01.plus.net [84.93.249.140
4 235 ms 239 ms 242 ms xe-8-2-0.pcl-cr01.plus.net [212.159.1.8]
5 91 ms 58 ms 58 ms ae2.pcl-cr02.plus.net [195.166.129.7]
6 64 ms 59 ms 61 ms ae1.ptw-cr02.plus.net [195.166.129.2]
7 63 ms 67 ms 68 ms 72.14.223.32
8 40 ms 35 ms 35 ms 209.85.252.186
9 21 ms 22 ms 22 ms 72.14.238.51
10 25 ms 22 ms 22 ms lhr08s01-in-f14.1e100.net [173.194.41.78]
Trace complete.
22-01-2013 8:26 PM
22-01-2013 8:31 PM
22-01-2013 8:33 PM
Alex
22-01-2013 8:38 PM
22-01-2013 9:46 PM
22-01-2013 9:51 PM
22-01-2013 9:53 PM
So if you're having the issue, log in to your router and disconnect/reconnect until usertools.plus.net/@gateway shows that you're not on a PCL gateway and you should be good.
24-01-2013 12:04 PM
