Cant send email when using webmail
- Cant send email when using webmail
31-12-2012 8:44 PM
HI
When trying to send mail whilst using webmail (plusnet betamail ) about 80 - 90 % of the attempts i get an error message saying SMPT error cant connect to server.
Frustratingly i copy the message and paste into the old basic email..... the mail instantly transmits.
So do i have incorrect settings ? Or are the servers unreliable ?
Should i play safe and forget betamail and revert to basic mail ?
Happy new year .
Keppy
Happy new year .
Keppy
Message 1 of 5
(1,747 Views)
4 REPLIES 4
Re: Cant send email when using webmail
31-12-2012 11:00 PM
You should not be using beta webmail now. Roundcube became the standard webmail offering last April and is accessed at https://webmail.plus.net/. Is it this one or its old beta implementation that fails for you?
I've just tried sending from webmail (Roundcube) and it worked OK - admittedly a sample of one.
David
Message 2 of 5
(663 Views)
01-01-2013 11:30 AM
HI
Hopefully you have pinpointed the problem.... have been using https://betawebmail.plus.net/ ; , why does it remain available ?
Have just tried https://webmail.plus.net/ ; and first attempt success.
Fingers crossed this post now closed .
Happy and Healthy New Year to all forum readers.
keppy
Message 3 of 5
(663 Views)
02-01-2013 5:45 PM
This is exactly the same problem that I've been suffering with for months - refer my last posting at Unable to send emails
I will now reset my shortcut to see if the problem goes away.
Message 4 of 5
(663 Views)
05-01-2013 11:03 PM
I've commented on the other thread.
Message 5 of 5
(663 Views)
